Haproxy using systemctl
Hi
Did anyone using compiled version of haproxy on RHEL 7.x or derivatives? We have been running compiled version successfully last few years on RHEL 6.7 platform successfully. recently we migrated to RHEL 7.x, thus compiled using the same option which we are using on RHEL 7.x build system. i am having intermediate down every few days. Not seeing any relevent messages on logs ( /var/logs/messages or haproxy notiice logs) not sure why it is going down every few days and we have to issue reload to make it work again.
only noticeable difference is system-wrapper script and systemctl script. I am using system-wrapper generated from compiled version and using unit file from haproxy contribution directory.
unit file:
cat etc/systemd/system/haproxy-80.service
[Unit]
After=syslog.target network.target
[Service]
Environment=“CONFIG=/opt/haproxy/haproxy-80/conf/haproxy.conf” "PIDFILE=/run/haproxy-80.pid"
ExecStartPre=/opt/haproxy/haproxy-80/sbin/haproxy-80 -f $CONFIG -c -q
ExecStart=/opt/haproxy/haproxy-80/sbin/haproxy-80-systemd-wrapper -f $CONFIG -p $PIDFILE
ExecReload=/opt/haproxy/haproxy-80/sbin/haproxy-80 -f $CONFIG -c -q
KillMode=mixed
Restart=always
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=haproxy-80
Environment=NODE_ENV=production
[Install]
WantedBy=multi-user.target
Syslog file
$ cat etc/rsyslog.d/haproxy-80.conf
if ($programname == ‘haproxy-80’ and $syslogseverity-text == ‘info’) then -/opt/haproxy/logs/haproxy-80/haproxy-80-info.log
if ($programname == ‘haproxy-80’ and $syslogseverity-text == ‘notice’) then -/opt/haproxy/logs/haproxy-80/haproxy-80-notice.log
haproxy config file:
$ cat opt/haproxy/haproxy-80/conf/haproxy.conf
user www
group www
pidfile /var/run/haproxy-80.pid
log /dev/log local0 info
maxconn 50000
tune.bufsize 128000
tune.maxrewrite 1024
stats socket /var/run/haproxy-80.stat mode 600 level admin
stats timeout 2m
nbproc 1
tune.comp.maxlevel 5
option httplog clf
option tcp-smart-accept
option tcp-smart-connect
option splice-auto
no option logasap
timeout client 1m
timeout http-keep-alive 5s
timeout server 1m
timeout queue 1m
timeout check 10s
timeout http-request 10s
default-server maxconn 1024 inter 5s rise 5 fall 5
   errorfile 503 /opt/haproxy/errors/503.html
   errorfile 400 /opt/haproxy/errors/400.html
   errorfile 403 /opt/haproxy/errors/403.html
   errorfile 500 /opt/haproxy/errors/500.html
   errorfile 502 /opt/haproxy/errors/502.html
   errorfile 504 /opt/haproxy//errors/504.html
   errorfile 408 /dev/null
frontend IN
monitor-uri /proxy.html
log-format [%pid]\ [%Ts.%ms]\ %ac/%fc/%bc/%bq/%sc/%sq/%rc\ %Tq/%Tw/%Tc/%Tr/%Tt\ %tsc\ %ci:%cp\ %fi:%fp\ %si:%sp\ %ft\ %{+Q}r\ %ST\ %b:%s\ “%CC”\ “%hr”\ “%CS”\ “%hs”\ ireq_size=%U\ resp_size=%B
unique-id-format %{+X}o\ %ci:%cp
%fi:%fp_%Ts_%rt:%pid
unique-id-header X-Unique-ID
Blacklist: Deny access to some IPs before anything else is checked
tcp-request content reject if { src -f /opt/haproxy/security/rules/blacklist.lst }
Whitelist: Allow IPs to bypass the filters
http-request allow if { src -f /opt/haproxy/security/rules/whitelist.lst }
    reqadd                X-Forwarded-Proto:\ http
    reqadd                X-Forwarded-Port:\ 80
    rspdel                ^Server:.*
    rspdel                ^X-Powered-By:.*
    rspdel                ^X-Runtime:.*
capture request header X-Forwarded-For len 500
capture request header Host len 500
capture request header Accept-Encoding len 32
capture response header Location len 64
capture response header Content-Type len 64
capture request header Referrer len 64
capture request header Content-Length len 10
capture request header X-Unique-ID len 64
default_backend sso_server
Compile flags:
./haproxy-80 -vv
HA-Proxy version 1.6.9 2016/08/30
TARGET = linux2628
CPU = native
CC = gcc
CFLAGS = -O2 -march=native -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS = USE_LIBCRYPT=1 USE_ZLIB=yes USE_OPENSSL=1 USE_STATIC_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2j 26 Sep 2016
Running on OpenSSL version : OpenSSL 1.0.2j 26 Sep 2016
Built without Lua support
PS output:
www 1451 18205 0 Oct18 ? 00:00:00 /opt/haproxy/haproxy-80/sbin/haproxy-80 -f /opt/haproxy/haproxy-80/conf/haproxy.conf -p /run/haproxy-80.pid -Ds -sf 18209
www 1452 1451 0 Oct18 ? 00:53:31 /opt/haproxy/haproxy-80/sbin/haproxy-80 -f /opt/haproxy/haproxy-80/conf/haproxy.conf -p /run/haproxy-80.pid -Ds -sf 18209
root 18205 1 0 Oct11 ? 00:00:00 /opt/haproxy/haproxy-80/sbin/haproxy-80-systemd-wrapper -f /opt/haproxy/haproxy-80/conf/haproxy.conf -p /run/haproxy-80.pid
root 18219 1 0 Oct11 ? 00:00:00 /opt/haproxy/haproxy-443/sbin/haproxy-443-systemd-wrapper -f /opt/haproxy/haproxy-443/conf/haproxy.conf -p /run/haproxy-443.pid
wwwssl 28231 18219 0 Oct28 ? 00:00:00 /opt/haproxy/haproxy-443/sbin/haproxy-443 -f /opt/haproxy/haproxy-443/conf/haproxy.conf -p /run/haproxy-443.pid -Ds -sf 26752
wwwssl 28232 28231 0 Oct28 ? 00:09:01 /opt/haproxy/haproxy-443/sbin/haproxy-443 -f /opt/haproxy/haproxy-443/conf/haproxy.conf -p /run/haproxy-443.pid -Ds -sf 26752
any did one had similar experience? or any one using haproxy successfully on rhel platform using systemd based service management?
any help is highly appreciated. unable to breakthrough this issue due to insufficient log why it is failing every few days.
Srinivas Kotaru
