I am using HAproxy 1.5.8 version for http and now try to add websocket support.
I am testing using http://www.websocket.org/echo.html site for websocket connection.
My websocket connection connects to the server but after around few seconds it shows disconnected.
My setup is like this:
AWS ALB -----> HAproxy ------> ec2 with web app docker container
I have enabled the session stickiness attribute on AWS ALB.
haproxy conf:
timeout connect 5000ms
timeout client 5000ms
timeout server 50000ms
timeout tunnel 3600s
timeout client-fin 30s
timeout http-keep-alive 1s
frontend public
bind 0.0.0.0:80
maxconn 2500
monitor-uri /haproxy_health
# remove proxy header
http-request del-header Proxy
## **WS routing based on Host header
acl host_ws hdr_beg(Host) -i ws.
use_backend meteoguard-task-list-service-eis if host_ws
## **WS routing based on websocket protocol header
acl hdr_connection_upgrade hdr(Connection) -i upgrade
acl hdr_upgrade_websocket hdr(Upgrade) -i websocket
use_backend meteoguard-task-list-service-eis if hdr_connection_upgrade hdr_upgrade_websocket
timeout connect 30s
timeout client 30s
timeout server 30s
timeout tunnel 60m
## websocket protocol validation
acl hdr_websocket_key hdr_cnt(Sec-WebSocket-Key) eq 1
acl hdr_websocket_version hdr_cnt(Sec-WebSocket-Version) eq 1
http-request deny if ! hdr_connection_upgrade ! hdr_upgrade_websocket ! hdr_websocket_key ! hdr_websocket_version
option httpchk GET /health
http-check expect status 200
server ws1 10.3.1.2:31402 check
