Hello people,
i got some trouble with websocket applications behind haproxy.
I can connect to the applications without any problems but after a shot periode of time (4-5 seconds) the applications says “disconnected” (in different flavors deppends on the application ;)). The Applications for example are: Estos ProCall (uses Websocket for mobile app communication), Innovaphone myApps (does everything with websocket) and NodeRed.
The HAProxy Log doesn´t show anything (severity “info”). NodeRed says “connection lost” but there is no entry in haproxy log. I read a lot about other people having a similar issue, but non of the suggested solution seems to help.
Here my config:
# Global Parameters
log 127.0.0.1:514 local0 notice
pidfile /var/run/haproxy.pid
maxconn 4096
log 127.0.0.1 local0 debug
ssl-server-verify none
# Default Parameters
timeout http-request 15s
timeout queue 30s
timeout client 5000
timeout server 25s
timeout http-keep-alive 1s
timeout check 10s
timeout tunnel 3600s
timeout tarpit 60s
# Frontend Redirect 80->443 WAN Interface
frontend http_redirect_wan
bind ip.add.re.ss:80
# Frontend Application LAN Interface
frontend https_lan
bind ip.add.re.ss:443 ssl crt ***.pem
option forwardfor header X-Real-IP
http-request set-header X-Real-IP %[src]
# Frontend Application ACLs
acl acl_red ssl_fc_sni red.example.de
# Backend Forwarding
use_backend lan-l-app03_nodered if acl_red
# Backend Definitions
server lan-l-app03_nodered ip.add.re.ss:1880 check
timeout server 500m
timeout connect 500m
timeout queue 500m
cookie io prefix indirect nocache
Dont get nervous about the timeouts, i tried a lot
Hope anybody can give me a suggestion
Thanks in advance!
