Hello!
I’ve faced with problem when tried to convert NGINX-configure to haproxy 2.3. The task is to redirect client from http:80 to https:443 and after success login switch HTTP to WebSocket. Also I have to send clientIP to backend via x-real-ip vs x-forwarded-for headers.
The websocket specific part of NGINX-config:
location / {
proxy_pass http://Farm;
proxy_http_version 1.1;
proxy_redirect off;
proxy_buffering off;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_connect_timeout 90;
proxy_send_timeout 90;
proxy_read_timeout 90;
But I cannot reproduce right behavior with haproxy. I think because don’t understand some details in it. Could I ask a piece of advice how to solve my task?
My haproxy-config is:
frontend j38-fr
bind ip-add:80
option forwardfor header X-Real-IP
timeout tunnel 1h
use_backend Farmbackend bk_web balance roundrobin server websrv1 servIP:22088
I used this manual (Websockets Load Balancing With HAProxy) in my case.
When client tryes to switch http to websocket I get error at devtools in browser “WebSocket connection to ‘wss://example.loc/12345’ failed”
If I turn on mode tcp in frontend and backend section and try to connect to http://example.loc I see that http part works correct but when go to “example.loc/12345” (http switch to websocket mode) I receive the same error at devTools console of the browser → WebSocket connection to ‘wss://example.loc/12345’ failed"
Config here:
frontend j38-fr
bind ip-add:80
timeout tunnel 1h
use_backend Farmbackend bk_web mode tcp balance roundrobin server websrv1 servIP:22088
In next case I added ssl options to frontend section (see config below). Now I manage to connect right. I don’t undestand how “bind ip-add:443 ssl crt file.pem” makes haproxy establish websocket in that case. Explain somebody, please ![]()
frontend j38-fr bind ip-add:80 bind ip-add:443 ssl crt file.pem mode tcp redirect scheme https if !{ ssl_fc } option forwardfor header X-Real-IP option http-server-close timeout tunnel 1h use_backend Farm backend bk_web mode tcp balance roundrobin server websrv1 servIP:22088
Question about use X-Real-IP and X-Forwarded-fore still opens
