Web socket in http mode
I’m trying to set up proxy in http mode using haproxy. The problem with tcp is that I need to read headers. So what I’m doing wrong? I was tried so many times with different configurations, but it just no working. (Nginx in that case works ok)
p.s. is reverse-proxied servers which available by subdomain
So I would be glad to get any advices with that problem
    log stdout format raw daemon debug
    timeout client  30s
    timeout server  30s
frontend ws_front
    bind *:8000
    http-request set-var(req.cleaned_host) hdr(host)
    http-request set-var(req.cleaned_host) var(req.cleaned_host),regsub(^.*://,)
    http-request set-var(req.cleaned_host) var(req.cleaned_host),regsub(:.*$,)
    http-request set-var(txn.backend_host) var(req.cleaned_host),map(/etc/haproxy/servers_map.txt)
    acl is_proxy1 var(txn.backend_host) -m dom proxy1
    acl is_proxy2 var(txn.backend_host) -m dom old
    acl is_websocket hdr(Upgrade) -I WebSocket
    acl is_websocket hdr_beg(Host) -I ws
    use_backend nginx_ws_proxy if is_proxy1
    use_backend nginx_ws_old if is_proxy2
    http-request set-header Host <subdomain><domain>
    option forwardfor # This sets X-Forwarded-For
    timeout queue 5000
    timeout server 5000
    server nginx_srv <ip1>:8000 ssl verify none
    server nginx_srv <ip2>:8002 ssl verify none
