HAProxy with SQL2019 AlwaysOn
I tried to make a config with MS SQL 2019 Always On.
I have 2 SQL nodes in my cluster Always On, and I Have multiples Always On groups.
IP xx.xx.xx.248 is for one listener in one of my Always On group.
IP xx.xx.xx.11 and 12 are my two nodes.
Here is my config :
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 6000
stats timeout 2m
timeout http-request 10s
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 6000
frontend sqldev
bind xx.xx.xx.248:1433
use_backend sqldev
backend sqldev
option log-health-checks
timeout server 1m
server DEVSQL1 xx.xx.xx.11:1433 check
server DEVSQL2 xx.xx.xx.12:1433 check
At this step, my connexions are redirected to my secondary node in read only :frowning: I don’t know how to redirect the write connexions only to the primary server and the read connexion to one of this two nodes.
I think HAProxy doesn’t know which is the primary node.
What is the good configuration to work with SQL 2019 Always On groups and listener ?
