How many stick counters are currently supported?
In Haproxy opensource version, How many stick counters are supported? One AI said currently sc0-sc9 are supported, but I can’t see the doc anywhere
Please see:
tune.stick-counters
Sets the number of stick-counters that may be tracked at the same time by a connection or a request via “track-sc*” actions in “tcp-request” or “http-request” rules. The default value is set at build time by the macro MAX_SESS_STK_CTR, and defaults to 3. With this setting it is possible to change the value and ignore the one passed at build time. Increasing this value may be needed when porting complex configurations to haproxy, but users are warned against the costs: each entry takes 16 bytes per connection and 16 bytes per request, all of which need to be allocated and zeroed for all requests even when not used. As such a value of 10 will inflate the memory consumption per request by 320 bytes and will cause this memory to be erased for each request, which does have measurable CPU impacts. Conversely, when no “track-sc” rules are used, the value may be lowered (0 being valid to entirely disable stick-counters).
