Hey guys,
Having issues finding out the difference between Enterprise and the CE in reference to how many stick tables I can use per instance?
Can someone point me in the right direction?
Hey guys,
since Haproxy 2.8 you can change the number via the global configuration option tune.stick-counters
Before Haproxy 2.8 recompiling with a custom MAX_SESS_STKCTR value was necessary.
