Hi
I hve tried to compile HAProxy after what I have found by googling a round
make TARGET=linux-glibc CPU=native USE_STATIC_PCRE=1 USE_OPENSSL=1.1.1 USE_ZLIB=1
sudo make install
sudo touch /etc/init.d/haproxy
sudo chmod +x /etc/init.d/haproxy
sudo nano /etc/init.d/haproxy
sudo mkdir /etc/haproxy
sudo nano /etc/haproxy/haproxy.cfg
At this stage I have not seen any errors.
Then I run
sudo service haproxy start
Failed to start haproxy.service: Unit haproxy.service not found.
Any suggestions how to fix this. And also are there and official guide to compile HAProxy?
HAProxy -vv output do not shows any problemsadministrator@HAProxy:/$ haproxy -vv
HA-Proxy version 2.2.2 2020/07/31 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.2.html
Running on: Linux 5.8.0-050800-generic #202008022230 SMP Sun Aug 2 22:33:21 UTC 2020 x86_64
TARGET = linux-glibc
CPU = native
CC = gcc
CFLAGS = -O2 -march=native -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-stringop-overflow -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_STATIC_PCRE=1 USE_OPENSSL=1.1.1 USE_ZLIB=1
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE +STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Running on OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Built with gcc compiler version 9.3.0
: mode=HTTP side=FE|BE mux=H1
Available services : none
Regards
Henning
