I have an issue with our haproxy setup, cookie persistence works for http but when the site switches to https the user hits another server. We are using https passthrough as we have certificates installed on the servers and dont want encrypted traffic on our network.
Config is below:
frontend http-in
bind 192.168.1.159:80
default_backend http
frontend https-in
bind 192.168.1.159:443
capture cookie ASP.NET_SessionId len 32
default_backend https
static backend for serving up images, stylesheets and such
#backend static
server static 127.0.0.1:4331 check
Least connections balancing between the various backends
backend http
stick-table type ip size 20k expire 30m
cookie SITEID insert indirect nocache
server server1 x.x.x.x:80 weight 25 cookie server1 check
server server2 x.x.x.x:80 weight 25 cookie server2 check
backend https
stick-table type ip size 200k expire 30m
stick on src
server server1 x.x.x.x:443 check
server server2 x.x.x.x:443 check
