IP routing with haproxy tcp for ftp
Hi guys,
My configuration:
server1
ha proxy 1.5.14 - centos 7
public ip eth0 : 1.2.3.4
public ip eth0:0 : 5.6.7.8 (ovh ip failover which can point to another haproxy server when failover occured)
server3
vsftp server 3.0.2 - centos7
public ip eth0: 9.10.11.12
Only public addresses. server1 and server3 have backups in a pacemaker cluster (active / passive) : server2 (haproxy backup) and server4 (ftp backup)
When I connect in passive mode to server3 : no problem.
When I connect in passive mode to server1 (on 5.6.7.8):
ftp *****.com
Connected to *****.com (5.6.7.8).
220 Welcome to FTP service.
Name (******.com:root): toto
331 Please specify the password.
Password:
230 Login successful.
Remote system type is UNIX.
Using binary mode to transfer files.
ftp> ls
227 Entering Passive Mode (9,10,11,12,198,124).
ftp: connect: Connexion terminée par expiration du délai d'attente
=> in english : timeout
I take a look at /var/log/messages on the client and see
Sep 8 12:26:47 ***** kernel: [11686946.541337] Firewall: *TCP_OUT Blocked* IN= OUT=eth2 SRC=******* DST=9.10.11.12 LEN=60 TOS=0x00 PREC=0x00 TTL=64 ID=45793 DF PROTO=TCP SPT=52258 DPT=50812 WINDOW=29200 RES=0x00 SYN URGP=0 UID=0 GID=0
The client try to connect directly to server3 and not to server1. I think that the packets are blocked because packets should be iptables RELATED to server1 and not to server3 to pass the firewall.
I don’t want to change iptables output rules because it concerns a lot of clients.
Is there a way to respond to server1 and not to server3 (or another way to work properly)?
server1 : haproxy.cfg
listen ftplb 5.6.7.8:21, 5.6.7.8:50000-50999
server server3 9.10.11.12 check port 21
server server4 13.14.15.16 check port 21
server1 et server3 : iptables
-A INPUT -p tcp -i eth0 -m multiport --dport 21,50000:50999 -m conntrack --ctstate NEW,ESTABLISHED,RELATED -j ACCEPT
server3 vsftpd.conf
anonymous_enable=NO
local_enable=YES
write_enable=YES
local_umask=022
dirmessage_enable=YES
xferlog_enable=YES
xferlog_std_format=YES
chroot_local_user=YES
listen=YES
pam_service_name=vsftpd
userlist_enable=YES
tcp_wrappers=YES
allow_writeable_chroot=YES
ftpd_banner=Welcome to FTP service.
pasv_enable=YES
pasv_promiscuous=YES
pasv_min_port=50000
pasv_max_port=50999
dual_log_enable=YES
log_ftp_protocol=YES
port_enable=YES
port_promiscuous=YES
connect_from_port_20=NO
seccomp_sandbox=NO
Any idea?
Regards,
Eric
The proper solution is to configure a dedicated range of ports on server3 and open that range on iptables.
If thats not what you want, for whatever reason, then you need to look at a proxy server that intercepts FTP message and redirects data traffic as well. Haproxy does not do that (as it is not a FTP proxy, but a TCP proxy in this case).
Quick sidenote: iptables would also fail to open passive ports when you would use FTP with SSL. Once you enable SSL, iptables FTP helper are no longer able to intercept the passive ports, meaning it would be closed. Relying on those FTP helpers in iptables is therefor almost always a bad idea.
Thank you for your response.
Already done.
Do you know ftp proxies? ftp-proxy seems to be outdated…
I won’t use FTP with SSL. I use SFTP with haproxy and It works well.
Eric
No, I don’t. You could also forward the passive port range from haproxy to your backend FTP server. That would probably be the easiest way.
You would force the FTP server to announce the IP of haproxy in the control channel, and forward the pasv ports as well through haproxy.
This is what’s explained here and is actually the simplest approach:
I’ve ever seen this link and it helped me. But if I add in /etc/vsftp/vsftp.conf pasv_address=5.6.7.8:
  • client firewall doesn’t block output packets : OK
  • but I get
    ftp failover fqdn
    Connected to failover fqdn (5.6.7.8).
    Name (failover fqdn:root): toto
    Password:
    ftp> ls
    227 Entering Passive Mode (5,6,7,8,196,94).
    ftp: connect: Connexion refusée
    => connection refused
Did you configure haproxy correctly? How does the configuration look like?
    log         127.0.0.1 local2
    chroot      /var/lib/haproxy
    maxconn     1000
    #user        haproxy
    #group       haproxy
    # turn on stats unix socket
    mode                    http
    option                  http-server-close
    option                  forwardfor       except 127.0.0.0/8
    retries                 3
    timeout http-request    10s
    timeout queue           1m
    timeout connect         10s
    timeout client          1m
    timeout server          1m
    timeout http-keep-alive 10s
    timeout check           10s
frontend stats
        bind 5.6.7.8:8080
        stats uri /******
        stats auth ****:******
listen ftplb2 5.6.7.8:21, 5.6.7.8:50000-50999
    server server3 9.10.11.12 check port 21 source interface eth0:0
    server server4 13.14.15.16 check port 21 source interface eth0:0
where eth0:0=5.6.7.8
Does haproxy actually listen on the port range?
You would be better up configuring a proper frontend/backend section, instead of using this obsolete approach with the listen section. And don’t use “source interface”, specify the source IP.
frontend ftplb2
 bind 5.6.7.8:21
 bind 5.6.7.8:50000-50999
 default_backend ftpservers
backend ftpservers
 server server3 9.10.11.12 check port 21 source 5.6.7.8
 server server4 13.14.15.16 check port 21 source 5.6.7.8
Yes!!! It works in passive mode. THANK YOU!!!
Just a problem in active mode:
200 PORT command successful. Consider using PASV.
421 Service not available, remote server has closed connection
It’s week end time for me. I will retry on monday.
Thank you again.
From client (which accept all output traffic in firewall):
  • I can connect in active mode directly to ftp server (server3)
  • I can’t connect in active mode to ftp server by haproxy
In this situation no packets are blocked by firewall on server3 and server1.
For active mode to work you will have to NAT your active traffic through the haproxy box, otherwise the client will see the active connection attempt from a different IP (the IP of server3 instead of the IP of the haproxy box) and will close the connection.
Thanks for your help.
I add this rule on ftp server
-A POSTROUTING -p tcp -o eth0 -j SNAT --to 5.6.7.8
It doesn’t work. tcpdump says:
08:53:34.562777 IP 5.6.7.8.35191 > client's private ip.50301: Flags [S], seq 113635828, win 29200, options [mss 1460,sackOK,TS val 1309390568 ecr 0,nop,wscale 7], length 0
Without the rule it was
08:54:19.567917 IP ftp server ip.41179 > client's private ip.51138: Flags [S], seq 1040902272, win 29200, options [mss 1460,sackOK,TS val 1309435573 ecr 0,nop,wscale 7], length 0
So the iptables rule is OK : the packet is from 5.6.7.8 (haproxy). But ftp server replies to the client’s private ip (and not the client’s public ip). But why?
Because the client is behind NAT, incorrectly configured and the NAT gateway doesn’t have an “ftp helper”.
You have to use a properly configured FTP client.
edit: I don’t think the iptables configuration suffices though; you would have to tunnel to the haproxy box and NAT it there, as your FTP doesn’t have see traffic desalinated to 5.6.7.8. You will also have to restrict the tunnel+NAT rule to only the active traffic. This goes beyond what we can support here.
When you are using PASV the server will tell the client which IP and port to connect to. - so you’ll have to set up the server to tell the client to connect to your Proxy-server. - look for something like ‘firewall support’
Remember also that you must configure individual portranges for PASV on the servers, and setup the rules for that in haproxy.
So setup one rule for port 21 that does roundrobin (or leastconn) - remember to set ‘timeout tunnel’, as the server will shut down the session if this conn disappears.
Then setup one rule for each of the servers to listen for the PASV portrange eg:
listen ftp
bind *:21
timeout tunnel 300s
server ftp1 x.y.x.i check port 21
server ftp2 x.y.z.ii check port 21
listen ftp_pasv1
bind *:63535-64534
server ftp1 x.y.z.i check port 21
listen ftp_pasv2
bind *:64535-65535
