Ftp connexion trough haproxy
Hello!
At the moment I have two servers under centos 7.
  • 10.10.104.200 = Loadbalencer with Haproxy
  • 10.10.105.100 = web server
I want the clients to enter their ftp (ex Filezilla) 10.10.104.200 and be redirected automatically to the server 10.10.105.100. I still have not found a way that works well … Thank you very much for helping me.
Here is my current configuration of haproxy.cfg:
maxconn 10000
frontend http_front
default_backend http_back
backend http_back
server serveurBack 10.10.105.100:80 check
bind *:8181
stats uri /
stats auth :
frontend ftp-pool
bind *:21 transparent
bind *:30000-35020 transparent
maxconn 2000
option tcp-check
default_backend ftp-pool-backend
balance source
hash-type consistent
server ftp01 10.10.105.100 check port 21
backend ftp-pool-backend-static
balance source
THX!
Have a good day
You need to set PASV address to your external IP in ftp configuration.
