Hello
How can I make FTP Connection?
This is conf file:
log 127.0.0.1 local0
log 127.0.0.1 local1 notice
#log loghost local0 info
maxconn 4096
#debug
#quiet
redispatch
maxconn 2000
contimeout 5000
clitimeout 50000
srvtimeout 50000
bind *:8080
option httpclose
stats show-legends
stats refresh 5s
stats uri /stats
stats auth loadbalancer:loadbalancer
stats admin if TRUE
frontend MAIN
bind *:21
bind *:143
bind *:443
bind *:993
acl domain1_URL hdr_dom(host) -i domain1.com
acl domain2_URL hdr_dom(host) -i domain2.com
acl domain3_URL hdr_dom(host) -i domain3.com
use_backend domain1 if domain1_URL
use_backend domain2 if domain2_URL
use_backend domain3 if domain3_URL
backend domain1
server web-first 192.168.1.124:80
backend domain2
server web-second 192.168.1.197:80
backend domain3
server web-third 192.168.1.197:80
Stop using mode http first of all. You cannot tell haproxy to use HTTP mode when actually you are using FTP, IMAP and everything but HTTP.
Use mode tcp instead. This will break your host header matching (host header matching can only work with HTTP of course).
Also you need to configure a port range for passive transfers and forward that port range as well.
You probably want to explain what it is that you are trying to achieve here, especially with all the other protocols like IMAP, etc.
I changed, mode tcp with mode http and I added this:
listen FTP
bind *:21,:10000-10250
server ftp01 192.168.1.197 check port 21
FileZilla Log:
[FTP]
|Status:|Connecting to PUBLIC IP:21...|
|Status:|Connection established, waiting for welcome message...|
|Status:|Initializing TLS...|
|Status:|Verifying certificate...|
|Status:|TLS connection established.|
|Status:|Server does not support non-ASCII characters.|
|Status:|Logged in|
|Status:|Retrieving directory listing...|
|Status:|Server sent passive reply with unroutable address. Using server address instead.|
|Command:|MLSD|
|Error:|The data connection could not be established: ECONNREFUSED - Connection refused by server|
[SFTP]
|Status:|Connecting to PUBLIC IP...|
|Response:|fzSftp started, protocol_version=8|
|Command:|open "Username@PUBLIC IP" 22|
|Command:|Pass: ******************|
|Error:|Authentication failed.|
|Error:|Critical error: Could not connect to server|
HAproxy Status:
[root@rp ~]# systemctl status haproxy.service
● haproxy.service - SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments.
Loaded: loaded (/etc/rc.d/init.d/haproxy; bad; vendor preset: disabled)
Active: active (running) since Mon 2018-04-09 20:07:58 UTC; 15s ago
Docs: man:systemd-sysv-generator(8)
Process: 12586 ExecStop=/etc/rc.d/init.d/haproxy stop (code=exited, status=0/SUCCESS)
Process: 12594 ExecStart=/etc/rc.d/init.d/haproxy start (code=exited, status=0/SUCCESS)
Main PID: 12603 (haproxy)
└─12603 /usr/sbin/haproxy -D -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid
Apr 09 20:07:58 rp.domain.com systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments....
Apr 09 20:07:58 rp.domain.com haproxy[12594]: Starting haproxy: [WARNING] 098/200758 (12602) : parsing [/etc/haproxy/haproxy.cfg:17] : 'option httplog' not usable with proxy 'FTP' (needs 'mode http'). Falling back to 'option tcplog'.
Apr 09 20:07:58 rp.domain.com haproxy[12594]: [WARNING] 098/200758 (12602) : config : 'option forwardfor' ignored for proxy 'FTP' as it requires HTTP mode.
Apr 09 20:07:58 rp.domain.com haproxy[12594]: [WARNING] 098/200758 (12602) : [/usr/sbin/haproxy.main()] Cannot raise FD limit to 100291, limit is 4096.
Apr 09 20:07:58 rp.domain.com haproxy[12594]: [WARNING] 098/200758 (12602) : [/usr/sbin/haproxy.main()] FD limit (4096) too low for maxconn=50000/maxsock=100291. Please raise 'ulimit-n' to 100291 or more to avoid any trouble.
Apr 09 20:07:58 rp.domain.com haproxy[12594]: [ OK ]
Apr 09 20:07:58 rp.domain.com systemd[1]: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments..
Regarding the FTP issue:
you need to enable “Show detailed log” in Filezilla, otherwise the output is useless. Also, you need to make sure that the server is actually listening and accepting those ports, as well as using the correct public IP in the FTP announcement (as opposed to its on local and private IP, as seen in the log). Also you probably wanna share the entire haproxy configuration you are using right now.
Regarding the SFTP issue:
The authentication fails, probably because your are hitting the SSH server of the haproxy box, NOT your backend SSH server, because the SSH server is already listening on port 22 of your haproxy box. Decide whether you want to move the local sshd server port or the haproxy port to somewhere else. Also remember to actually configure port 22 forwarding in haproxy (you just showed a configuration forwarding port 21 and the passive range only).
Do I need to install FTP software in Haproxy? or do I need to change settings on other server?
HAprox Conf. last version of the file:
https://pastebin.com/iNrPbykd
Detailed Log:
FTP
| Status: |
Connecting to PUBLIC IP:21… |
| Status: |
Connection established, waiting for welcome message… |
| Response: |
220---------- Welcome to Pure-FTPd [privsep] [TLS] ---------- |
| Response: |
220-You are user number 2 of 50 allowed. |
| Response: |
220-Local time is now 09:06. Server port: 21. |
| Response: |
220-This is a private system - No anonymous login |
| Response: |
220-IPv6 connections are also welcome on this server. |
| Response: |
220 You will be disconnected after 15 minutes of inactivity. |
| Command: |
AUTH TLS |
| Response: |
234 AUTH TLS OK. |
| Status: |
Initializing TLS… |
| Status: |
Verifying certificate… |
| Status: |
TLS connection established. |
| Command: |
USER myUserName |
| Response: |
331 User myUserName OK. Password required |
| Command: |
PASS ****************** |
| Response: |
230 OK. Current restricted directory is / |
| Status: |
Server does not support non-ASCII characters. |
| Command: |
PBSZ 0 |
| Response: |
200 PBSZ=0 |
| Command: |
PROT P |
| Response: |
200 Data protection level set to “private” |
| Status: |
Logged in |
| Status: |
Retrieving directory listing… |
| Command: |
PWD |
| Response: |
257 “/” is your current location |
| Command: |
TYPE I |
| Response: |
200 TYPE is now 8-bit binary |
| Command: |
PASV |
| Response: |
227 Entering Passive Mode (192,168,1,197,62,55) |
| Status: |
Server sent passive reply with unroutable address. Using server address instead. |
| Command: |
MLSD |
| Error: |
The data connection could not be established: ECONNREFUSED - Connection refused by server |
SFTP
| Status: |
Connecting to PUBLIC IP… |
| Response: |
fzSftp started, protocol_version=8 |
| Command: |
open “myUserName@PUBLIC IP” 22 |
| Command: |
Pass: ****************** |
| Error: |
Authentication failed. |
| Error: |
Critical error: Could not connect to server |
| Status: |
Disconnected from server |
| Status: |
Selected port usually in use by a different protocol. |
| Status: |
| Response: |
| Command: |
open “myUserName@PUBLIC IP” 21 |
| Error: |
Server unexpectedly closed network connection |
| Error: |
HAproxy Status
Active: active (running) since Tue 2018-04-10 06:11:04 UTC; 6min ago
Process: 406 ExecStop=/etc/rc.d/init.d/haproxy stop (code=exited, status=0/SUCCESS)
Process: 415 ExecStart=/etc/rc.d/init.d/haproxy start (code=exited, status=0/SUCCESS)
Main PID: 424 (haproxy)
└─424 /usr/sbin/haproxy -D -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid
Apr 10 06:11:04 rp.domain.com systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments....
Apr 10 06:11:04 rp.domain.com haproxy[415]: Starting haproxy: [WARNING] 099/061104 (423) : parsing [/etc/haproxy/haproxy.cfg:25] : 'option httplog' not usable with proxy...on tcplog'.
Apr 10 06:11:04 rp.domain.com haproxy[415]: [WARNING] 099/061104 (423) : config : 'option forwardfor' ignored for proxy 'FTP' as it requires HTTP mode.
Apr 10 06:11:04 rp.domain.com haproxy[415]: [WARNING] 099/061104 (423) : [/usr/sbin/haproxy.main()] Cannot raise FD limit to 100295, limit is 4096.
Apr 10 06:11:04 rp.domain.com haproxy[415]: [WARNING] 099/061104 (423) : [/usr/sbin/haproxy.main()] FD limit (4096) too low for maxconn=50000/maxsock=100295. Please rais...ny trouble.
Apr 10 06:11:04 rp.domain.com haproxy[415]: [ OK ]
Apr 10 06:11:04 rp.domain.com systemd[1]: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments..
Hint: Some lines were ellipsized, use -l to show in full.
First of all, drop all those port bindings from frontend MAIN, you cannot bind port 21 in that frontend and then bind it later on again, in the listen section.
As a matter of fact, drop all non HTTP ports including 443 from the frontend MAIN. You are just piling lots and lots of completely wrong configuration on each other causing a huge mess.
You need the adjust the settings on the FTP server I talked about earlier. However note that setting up FTP server behind a TCP reverse proxy is complicated and requires proper knowledge of how FTP works.
Regarding SFTP, I explained what happens here but from your tests I can see that you did not understand a single word of it. So let me elaborate: SFTP has nothing todo with FTP. Nothing at all. SFTP is based on SSH and allows transferring files through a SSH connection (port 22). Read more about SSH_File_Transfer_Protocol.
