Crushftp Behind HaProxy
Hi.
I’m tryng to set ftp (with explocit tls), ftps (implicit tls) and sftp with crushftp java software Behind HaProxy
Here is my haproxy configuration
frontend ftp
        bind *:2121
        bind *:20000-20998
        default_backend share-ftp
frontend ftps
        bind *:2990
        bind *:30000-30998
        default_backend share-ftps
frontend sftp
        bind *:2122
        default_backend share-sftp
backend share-ftp
        server rzv-app01-ftp rzv-app01-ftp.rozzano.diennea.lan check send-proxy-v2 port 2121
backend share-ftps
        server rzv-app01-ftp rzv-app01-ftp.rozzano.diennea.lan check send-proxy-v2 port 2990
backend share-sftp
        server rzv-app01-ftp rzv-app01-ftp.rozzano.diennea.lan check send-proxy-v2 port 2122
port 21 and 990 ar forwarded to 2121 and 2990, respectively, via iptables.
On the ftp server i’ve setup passive port ranges matching the haproxy configuration for ftp and ftps, and external ip address.
i’ve even enabled support for proxy protocol.
What Works:
  • sftp
  • plain ftp if i connect to port 2121
what dosen’t work:
  • ftp if i connect to port 21
  • ftp with explicit tls
  • ftps implicit tls
Someone can give mi a hint?
You need to remove port 2990 from the backend server.
Haproxy needs to connect the same port from the frontend to the backend server (30000 on the frontend needs to go to 30000 on the backend, not be forced to port 2121 or 2990, which is control plane, not the data plane).
Also I’m not convinced that your backend servers actually support the proxy protocol. How can you be certain that the support the binary v2 proxy protocol on both control and data plane ports?
Hi.
But from the documentation i’ve understood that port 2990 here is only for checks, rzv-app01-ftp.rozzano.diennea.lan:2990 would instead cause a redirection.
Anyway i’m sure that the backend support proxy protocol because is declared in teh documentation, and there are some opzion to enable it, so if it dosen’t work i definitely a bug, an this is a possibility.
Anyway…as said plain ftp on 2121 works well, this points me in the direction that the probelm is in my setup.
You are right, I confused this.
Not really:
https://www.crushftp.com/crush9wiki/Wiki.jsp?page=CrushBalance
Proxy protocol v1 support to tell the backend server your real IP (CrushFTP supports this).
V1 is supported, but you are forcing V2 on haproxy, which CrushFTP does not support.
I suggest you use send-proxy instead of send-proxy-v2.
Hi.
I’ve already tried using send-proxy (v1) protocol, but with no luck
Maybe the proxy protocol is only supposed to be enabled for the control protocol, not the data plane?
Maybe there is no issue with haproxy and crushftp at all and clear text FTP is the only protocol that works because a NAT helper is actually able to help out, while this is obviously not possible for FTP with TLS.
