Hi, I’m looking for some help as I ran out of options or maybe i am missing something.
I am sending a curl request towards and API with key authentication.
curl -v https://10.0.0.4/api/stass -H “X-API-KEY: hashedkey”
however, when passing through HAProxy, I am getting
[“Client KEY is not valid or header X-API-KEY not defined.”]
Is there anyway how I can forward the X-KEY header and it’s value as part of the header to the backend?
The basic configuration to send normal traffic to the backend works fine.
Haproxy will not strip this header. It will lowercases the header name though, due to the internal http representation.
But there is a simpler test:
Running curl against directly against the backend server, but lowercasing the header name (not the value),
curl -v https://10.0.0.4/api/stass -H "x-api-key: hashedkey"
If this doesn’t work, then your the backend server is not HTTP compliant as it HTTP header names are supposed to be case insensitive. If that is the case, then the following configuration would workaround this:
h1-case-adjust x-api-key X-API-KEY
Tried that but still getting the same response.
This is the haproxy config file.
timeout connect 36000s
timeout client 65s
timeout server 65s
frontend http-in
bind *:443 ssl crt /etc/haproxy/certs.d/ssl-certs.pem
default_backend http_backend
http-request capture req.hdr(X-Forwarded-For) len 64
#~~~ Get real IP if CloudFlare is present
acl from_cf src -f /etc/haproxy/cloudflare.lst
acl cf_ip_hdr req.hdr(CF-Connecting-IP) -m found
http-request set-var(txn.realip) req.hdr(CF-Connecting-IP) if from_cf cf_ip_hdr
http-request set-var(txn.realip) src if !from_cf
http-request set-header X-Real-IP %[var(txn.realip)]
http-request set-header X-Forwared-For %[var(txn.realip)] if !from_cf
#~~~ save src temporary, restore later
http-request set-var(txn.realsrc) src
http-request set-src var(txn.realip)
http-request add-header X-Forwarded-Port 443
http-request allow if { src -f /etc/haproxy/whitelist.lst }
http-request deny
#~~~ restore src original IP
http-request set-src var(txn.realsrc)
# Define hosts
acl abc_true hdr(host) -i 10.0.0.4
# Figure out which one to use
use_backend http_backend if abc_true
server abc abc:443 ssl verify none check
server abc_external abc_external:443 ssl verify none backup
Please do the test with curl I asked about.
Yes I did the curl with -H "x-api-key: and still the same output response
Then the issue is not about lower-casing the header name in haproxy.
As haproxy doesn’t strip the header, and the modification it applies (lower-casing) is not breaking the application, the root cause of the issue is something else.
You’d have to take a look at what the application actually receives, if there is nothing to be done on the application end, check if you can downgrade to HTTP and capture the haproxy → backend server traffic, or otherwise you will have to decrypt HTTPS in wireshark (by using the private key of the certificate in with a non-FS cipher).
