My first haprox setup is wrong
I have a vm with pihole running well. pihole is at 192.168.1.228. it has a working webmin running on lighttpd on port 80. from my pc I can access it at http://192.168.1.228/admin
it works
I tried to expose it using nat port forwarding on my router. ( port tcp 80 forwarded to port 80 at 192.168.1.228)
it works.
then i created a new vm with haproxy at 192.168.1.223. i removed previous forward rule and setup forwarding of port 80 tcp to .223
this is my config
        log /dev/log    local0
        log /dev/log    local1 notice
listen  stats
        bind            192.168.1.223:1936
        mode            tcp
        log             global
        maxconn 10
        clitimeout      100s
        srvtimeout      100s
        contimeout      100s
        timeout queue   100s
        stats hide-version
        stats refresh 30s
        stats show-node
        stats auth notadmin:notistherealpassword
        stats uri  /haproxy?stats
        log     global
        mode    tcp
        option  tcplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
frontend http
        acl acl_pihole2 hdr(host) -i pihole2.ismyservice.space
        use_backend pihole2_web if acl_pihole2
backend pihole2_web
        server web 192.168.1.228:80 check
service log
eealtebo@192.168.1.223:~$ tail /var/log/haproxy.log
Aug 21 20:46:49 haproxy1 haproxy[25006]: [WARNING] 232/204649 (25006) : parsing [/etc/haproxy/haproxy.cfg:30] : the 'clitimeout' directive is now deprecated in favor of 'timeout client', and will not be supported in future versions.
Aug 21 20:46:49 haproxy1 haproxy[25006]: [WARNING] 232/204649 (25006) : parsing [/etc/haproxy/haproxy.cfg:31] : the 'srvtimeout' directive is now deprecated in favor of 'timeout server', and will not be supported in future versions.
Aug 21 20:46:49 haproxy1 haproxy[25006]: [WARNING] 232/204649 (25006) : parsing [/etc/haproxy/haproxy.cfg:32] : the 'contimeout' directive is now deprecated in favor of 'timeout connect', and will not be supported in future versions.
Aug 21 20:46:49 haproxy1 haproxy[25006]: [WARNING] 232/204649 (25006) : config : 'stats' statement ignored for proxy 'stats' as it requires HTTP mode.
Aug 21 20:46:49 haproxy1 haproxy[25006]: Proxy stats started.
Aug 21 20:46:49 haproxy1 haproxy[25006]: Proxy http started.
Aug 21 20:46:49 haproxy1 haproxy[25006]: Proxy pihole2_web started.
If I try to access the service from outside the lan, i see in chrome that service not responds.
not a 404
i got ERR_CONNECTION_CLOSED
i tried using http://mypublicip:80/admin
I logged into the haproxy using ssh, and verified that pihole2 (228) is pingable and using curl I verified that wenserver replies well.
also, i tried from haproxy1 to run
realtebo@haproxy1:~$ curl http://pihole2.ismyservice.space:80/admin -sSL -vv
amd i see pihole2 admin webpage.
what am I doing wrong? why from outside i cannot see the web page?
I solved changing from tcpmode to http mode.
Why can’t this work with tcpmode?
Because you are accessing a HTTP variable: a http header. Can’t do that in tcp mode.
Use the default_backend directive in case you just want everything to go to a backend.
