Hey guys,
I successfully compiled HaProxy on SPARC/Solaris 11 with PCRE. The binary seems to execute ok, but I ran into a problem with sudo gmake install. I attached the full ouptut from the compiler here: https://pastebin.com/htEZTwBM but here’s the relevent part:
ehrz@sovms026:~/haproxy-1.7.5$ sudo gmake install
install -d "/usr/local/sbin"
install haproxy "/usr/local/sbin"
find: cycle detected for /lib/crypto/32/
find: cycle detected for /lib/32/
find: cycle detected for /lib/secure/32/
find: cycle detected for /usr/lib/lwp/32/
find: cycle detected for /usr/lib/32/
find: cycle detected for /usr/lib/security/32/
find: cycle detected for /usr/lib/elfedit/32/
find: cycle detected for /usr/lib/fm/topo/plugins/32/
find: cycle detected for /usr/lib/locale/en_US.UTF-8/32/
find: cycle detected for /usr/lib/locale/en_US.UTF-8/LC_CTYPE/32/
find: cycle detected for /usr/lib/locale/en_US.UTF-8/LO_LTYPE/32/
find: cycle detected for /usr/lib/secure/32/
find: cycle detected for /usr/lib/brand/solaris10/32/
find: cycle detected for /usr/lib/link_audit/32/
install: haproxy was not found anywhere!
gmake: *** [install-bin] Error 2
Anyway, thank you very much for an awesome product. I’m always finding new uses for haproxy!
And I’m afraid for this one too as well:
haproxy@formilux.org
Hi exabrial,
I am trying to install Haproxy on Solaris 11 and ran into the same error. Can you please send me through the steps on what worked for your Solaris installation?
Kiruthika
Try installing GNU find (//solaris/file/gnu-findutils).
After installing gnu-finutils as well facing the same error. Please help here.
Kiruthika
Did you actually compile haproxy properly? Please provide the entire output, not only the last two lines. And provide the output of ./haproxy -vv from the haproxy directory.
PFB the complete output of ./haproxy -vv
TARGET = solaris
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -fomit-frame-pointer -DFD_SETSIZE=65536 -D_REENTRANT -D_XOPEN_SOURCE=500 -D__EXTENSIONS__
OPTIONS =
Built without compression support (neither USE_ZLIB nor USE_SLZ are set)
Compression algorithms supported : identity(“identity”)
Built without OpenSSL support (USE_OPENSSL not set)
Built without PCRE support (using libc’s regex instead)
Built without Lua support
Total: 2 (2 usable), will use poll.
Kiruthika
