I’m fairly new to HAProxy so please assume there are multiple errors in my config
I’m trying to proxy two parts of my app.
gcd.abc.com/ => Amazon S3
and
gcd.abc.com/api => API Gateway
My frontends look like this:
frontend http-in
bind *:80 accept-proxy
capture request header Host len 64
# Permanent redirect HTTP to HTTPS
frontend https-in
bind *:443 accept-proxy ssl crt /etc/ssl/xyz.co.pem
# HTTP header Security
http-response del-header (Server|X-AspNet-Version|X-Powered-By)
acl gcd hdr_beg(host) -i gcd.
acl gcd_api hdr_beg(host) -i gcd. path_beg /api # I'm fairly sure this is wrong??
use_backend gcd-static if host_gcd
use_backend gcd-api if gcd_api
use_backend fia if { path_beg /service/ifm } #other stuff that works
use_backend calendar if { path_beg /service/calendar } #more other stuff which works
And my relevant backends look like this:
backend gcd-static
http-request set-header Host xbc.abc.co.s3-website-eu-west-1.amazonaws.com
server gcd-static s3.eu-west-1.amazonaws.com:80 check
backend gcd-api
http-request set-header Host foobar.execute-api.eu-west-1.amazonaws.com
http-request set-path /gcd/%[path]
server gcd-api foobar.execute-api.eu-west-1.amazonaws.com:443 ssl verify none sni str(foobar.execute-api.eu-west-1.amazonaws.com)
I have to admit some of this was copy-paste and I don’t know what some of the things are like sni and I’m not sure how to chain conditions together.
The problem that i’m getting is, I don’t get any data back when I curl like this:
curl -H "Host gcd.xyc.com" http://my_haproxy_ip
The log looks like this
Sep 26 10:45:16 ip-10-100-10-74 haproxy[10871]: 66.66.6.37:54329 [26/Sep/2019:10:45:16.866] http-in http-in/<NOSRV> 0/-1/-1/-1/0 301 105 - - LR-- 1/1/0/0/0 0/0 {gcd.xyz.com} "GET / HTTP/1.1" - - 1-5D8C96BC-5D6D0625D4390A6401CF0050
