We have two different denodo servers installed on two machines (LINUX) installed on AWS and one load balancer installed on one of those machines . Can you please provide the steps required or the configuration that need to be done to connect HA proxy with the available denodo servers . HA proxy should be able to connect either of the denodo server available .
Start by reading the haproxy starter guide. You can also checkout the blog posts on haproxy.com.
However you will have to invest some of your time into it.
I didn’t found anything regarding how to connect denodo servers available on AWS with the HA proxy .
I don’t know anything about denodo either. You will have to understand what you need from the load-balancer exactly, before you can find a solution.
