Greetings,
I’m using the following configuration of the HAproxy
[root@haproxy1 ~]# haproxy -v
HA-Proxy version 1.8.20 2019/04/25
Copyright 2000-2019 Willy Tarreau <willy@haproxy.org>
option log-health-checks
#option dontlognull
#option dontlog-normal
no option httpclose
backlog 10000
timeout connect 30s
timeout http-keep-alive 15s
timeout http-request 15s
timeout queue 30s
timeout tarpit 1m
timeout client 30s
timeout server 30s
default-server inter 5s rise 2 fall 3
stats refresh 30s
stats show-node
stats auth %commented%
stats uri %commented%
frontend web_frt
bind 192.168.60.7:443 ssl crt-list /etc/haproxy/cer.list
bind 192.168.60.7:80
acl not_https ssl_fc,not
acl is_ca_web hdr(host) -m str -i ca.crpt.ru
acl is_portal hdr(host) -m str -i portal.crpt.ru
acl is_autodiscover hdr(host) -m str -i autodiscover.crpt.ru
acl is_rpc path_beg -m beg -i /rpc/
acl is_owa path_beg -m beg -i /owa/
acl is_ews path_beg -m beg -i /ews/
acl is_oab path_beg -m beg -i /oab/
acl is_eas path_beg -m beg -i /eas/
acl is_mapi path_beg -m beg -i /mapi/
acl is_ecp path_beg -m beg -i /ecp/
acl is_healthcheck path_beg -m end -i healthcheck.htm
use_backend ca_web if is_ca_web
http-request deny if is_ecp
http-request deny if is_healthcheck
#http-request redirect scheme https code 301 if not_https
use_backend autodiscover_bck if is_autodiscover
use_backend rpc_bck if is_rpc
use_backend owa_bck if is_owa
use_backend ews_bck if is_ews
use_backend oab_bck if is_oab
use_backend eas_bck if is_eas
use_backend mapi_bck if is_mapi
use_backend portal_bck if is_portal
default_backend owa_bck
With this configuration I get my ca_web backend working on http. My my real goal is to force all backends, except for ca_web, to work with https. If I uncomment the http-request redirect scheme rule, I will get https redirection for the ca_web backend which is not acceptable. Is there any way to exclude ca_web backend from https redirection?
