after hours of searching and following sites like https://www.ssltrust.com.au/help/setup-guides/haproxy-reverse-proxy-setup-guide and https://discourse.haproxy.org/t/why-does-my-simplified-config-not-work-1-8-tcp-reverse-proxy-with-domain-name-checks/2448
i still can’t figure out, why haproxy won’t pass through https-requests:
My Setup:
domain1.com -------->:80, :443 1.2.3.4 ------> :81, :444 haproxy on pi1 --> :80, :443 pi1
else -------->:80, :443 1.2.3.4 ------> :81, :444 haproxy on pi1 --> :80, :443 pi2
so i have 2 domains, pointing to one ip, but should be handled by a separate raspberrypi, depending on the url.
pi1 is the target and the HAproxy host at the same time, which is why the apache webserver listens to ports 80 and 443, haproxy to 81 and 444.
The config of HAproxy:
log /dev/log local0 debug
log /dev/log local1 debug
backend pi2 _80
mod http
server pi2 pi2 :80 check
backend pi2_443
option ssl-hello-chk
server pi2 pi2 :443 check
backend pi1_80
server pi11 pi1:80
backend pi1_443
server pi11 pi1:443 check
frontend http
bind :81
use_backend pi2_80 if { hdr(host) -i domain2.com }
default_backend pi1_80
frontend https
bind :444
use_backend pi2_443 if { req_ssl_sni -i domain2.com }
default_backend pi1_443
More info:
My modem redirects from port 80 to 81, if it forwards directly to one of the two apache2 servers, it works perfectly fine.
When using curl -vvkl pi1 and curl -vvkl pi2 the apacheserver redirects from port :80 to port :443 and works perfectly fine. So the problem defenitely is haproxy here, but i cant figure out why.
haproxy -c -f /etc/haproxy/haproxy.cfg shows Configuration file is valid
changing the hostnames to IPs does not make a difference
Thanks for the help
