Hellow, just trying to wrap my head arround why i can’t setup acl rules on the filter like bellow lines.
I really don`t wanna send to coraza any message if is local network.
If i use if !is_local_network on the requests everything is okey i bypass the checks but still the messages arrive at coraza for no reason i know is local network and i dont care.
acl is_local_network src 192.168.1.0/24 192.168.40.0/24 10.10.10.0/24
filter spoe engine coraza config /etc/haproxy-coraza/coraza.cfg if !is_local_network
http-request send-spoe-group coraza coraza-req
http-request redirect code 302 location %[var(txn.coraza.data)] if { var(txn.coraza.action) -m str redirect }
http-request deny deny_status 403 hdr waf-block "request" if { var(txn.coraza.action) -m str deny }
http-request silent-drop if { var(txn.coraza.action) -m str drop }
http-request deny deny_status 500 if { var(txn.coraza.error) -m int gt 0 }
HAProxy version 3.3-dev3-d4d72e2 2025/07/11 - https://haproxy.org/
Status: development branch - not safe for use in production.
Known bugs: https://github.com/haproxy/haproxy/issues?q=is:issue+is:open
Running on: Linux 6.8.12-13-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-13 (2025-07-22T10:00Z) x86_64
TARGET = linux-musl
CC = cc
CFLAGS = -O2 -g -fwrapv
OPTIONS = USE_THREAD=1 USE_LINUX_TPROXY=1 USE_GETADDRINFO=1 USE_OPENSSL_AWSLC=1 USE_LUA=1 USE_ACCEPT4=1 USE_SLZ=1 USE_TFO=1 USE_QUIC=1 USE_PROMEX=1 USE_PCRE2=1 USE_PCRE2_JIT=1
DEBUG =
Feature list : -51DEGREES +ACCEPT4 +BACKTRACE -CLOSEFROM +CPU_AFFINITY +CRYPT_H -DEVICEATLAS +DL -ENGINE +EPOLL -EVPORTS +GETADDRINFO -KQUEUE -LIBATOMIC +LIBCRYPT +LINUX_CAP +LINUX_SPLICE +LINUX_TPROXY +LUA +MATH -MEMORY_PROFILING +NETFILTER +NS -OBSOLETE_LINKER +OPENSSL +OPENSSL_AWSLC -OPENSSL_WOLFSSL -OT -PCRE +PCRE2 +PCRE2_JIT -PCRE_JIT +POLL +PRCTL -PROCCTL +PROMEX -PTHREAD_EMULATION +QUIC -QUIC_OPENSSL_COMPAT +RT +SLZ +SSL -STATIC_PCRE -STATIC_PCRE2 +TFO +THREAD +THREAD_DUMP +TPROXY -WURFL -ZLIB
Built with multi-threading support (MAX_TGROUPS=32, MAX_THREADS=1024, default=40).
Built with SSL library version : OpenSSL 1.1.1 (compatible; AWS-LC 1.56.0)
Running on SSL library version : AWS-LC 1.56.0
SSL library supports TLS extensions : yes
SSL library supports SNI : yes
SSL library FIPS mode : no
SSL library supports : TLSv1.0 TLSv1.1 TLSv1.2 TLSv1.3
QUIC: connection socket-owner mode support : yes
QUIC: GSO emission support : yes
Built with Lua version : Lua 5.4.8
Built with PCRE2 version : 10.43 2024-02-16
Built with gcc compiler version 15.1.1 20250719
quic : mode=HTTP side=FE|BE mux=QUIC flags=HTX|NO_UPG|FRAMED
<default> : mode=SPOP side=BE mux=SPOP flags=HOL_RISK|NO_UPG
spop : mode=SPOP side=BE mux=SPOP flags=HOL_RISK|NO_UPG
[BWLIM] bwlim-in
[BWLIM] bwlim-out
[FCGI] fcgi-app
