I am running HAproxy for my Exchange 2019 Servers.
Everything is working as expected so far. This is my config:
# Global settings
log 127.0.0.1 local0 debug
stats socket /var/lib/haproxy/stats mode 660 level admin
# https://wiki.mozilla.org/Security/Server_Side_TLS#Recommended-configurations
#ssl-default-bind-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
#ssl-default-bind-options ssl-min-ver TLSv1.2 no-tls-tickets no-sslv3
# Defaults section
# Regarding timeout client and timeout server:
# https://discourse.haproxy.org/t/high-number-of-connection-resets-during-transfers-exchange-2013/1158/4
option prefer-last-server
no option httpclose
no option http-server-close
no option forceclose
no option http-tunnel
default-server inter 3s rise 2 fall 3
timeout client 600s
timeout http-request 10s
timeout connect 4s
timeout server 60s
# Stats section
bind *:444 ssl crt /etc/ssl/private/cert.pem
stats refresh 30s
stats show-node
stats auth admin:network21
stats uri /
stats admin if TRUE # Administration allowed
stats show-legends
# Main Front-Ends that proxy to the Back-Ends
frontend fe_default
bind *:80 name http
bind *:443 name https ssl crt /etc/ssl/private/cert.pem
capture response header Content-Length len 10
maxconn 10000
acl ssl_connection ssl_fc
acl letsencrypt path_beg /.well-known/acme-challenge/
acl path_autodiscover path_beg -i /Autodiscover/Autodiscover.xml
acl path_activesync path_beg -i /Microsoft-Server-ActiveSync
acl path_ews path_beg -i /ews/
acl path_owa path_beg -i /owa/
acl path_oa path_beg -i /rpc/rpcproxy.dll
acl path_ecp path_beg -i /ecp/
acl path_ps path_beg -i /powershell/
acl path_oab path_beg -i /oab/
acl path_mapi path_beg -i /mapi/
acl path_check path_end -i HealthCheck.htm
http-request redirect scheme https code 302 unless ssl_connection
http-request deny if path_check
use_backend be_letsencrypt if letsencrypt
use_backend be_exchange_https_autodiscover if path_autodiscover
use_backend be_exchange_https_activesync if path_activesync
use_backend be_exchange_https_ews if path_ews
use_backend be_exchange_https_owa if path_owa
use_backend be_exchange_https_oa if path_oa
use_backend be_exchange_https_ecp if path_ecp
use_backend be_exchange_https_ps if path_ps
use_backend be_exchange_https_oab if path_oab
use_backend be_exchange_https_mapi if path_mapi
default_backend be_exchange_https_default
frontend fe_smtp
bind *:25 name smtp
maxconn 100
default_backend be_smtp
# Back-Ends
option httpchk GET /Microsoft-Server-ActiveSync/HealthCheck.htm
http-check expect string 200\ OK
server ex1 10.32.0.51:443 ssl verify none maxconn 10000 weight 10 check
server ex2 10.32.0.52:443 ssl verify none maxconn 10000 weight 10 check
option httpchk GET /Autodiscover/HealthCheck.htm
option httpchk GET /ECP/HealthCheck.htm
option httpchk GET /EWS/HealthCheck.htm
option httpchk GET /mapi/HealthCheck.htm
timeout server 600s
option httpchk GET /OAB/HealthCheck.htm
option httpchk GET /RPC/HealthCheck.htm
timeout server 600s
option httpchk GET /owa/HealthCheck.htm
timeout server 60s
backend be_smtp
option smtpchk
server ex1 10.32.0.51:25 maxconn 100 weight 10 check
server ex2 10.32.0.52:25 maxconn 100 weight 10 check
Now I want to only allow access to the backends be_exchange_https_ecp and be_exchange_https_ps when the request is coming from 10.0.0.0/8.
I have tried all different methods I could find, for example
use_backend be_exchange_https_ps if path_ecp { src 10.0.0.0/8 } or
http-request deny if path_ecp { src 10.0.0.0/8 } or other non-inline variants but none of them seems to work.
Is there something else wrong with my configuration preventing the ACL from working?
Any help is greatly appreciated!
EDIT:
The HAPrxy is behind a NAT if that makes any difference.
