Syslog Forwarding with send-proxy not working
Hi community, I’ve tried for a few hours to have syslog forwarding enabling with send-proxy / send-proxy-v2 and neither of them is working properly.
What I want to achieve:
syslog input supporting both udp & tcp through haproxy to syslog-ng.
Environment info:
**haproxy -v**
HAProxy version 3.0.10-1ppa1~jammy 2025/04/25 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2029.
Known bugs: http://www.haproxy.org/bugs/bugs-3.0.10.html
Running on: Linux 5.15.0-136-generic #147-Ubuntu SMP Sat Mar 15 15:53:30 UTC 2025 x86_64
**syslog-ng -V**
syslog-ng 4 (4.8.2)
Config version: 4.2
Installer-Version: 4.8.2
Revision: 4.8.2-1
Compile-Date: May  7 2025 09:41:09
Config option 1 results
{"TRANSPORT":"rfc3164+proxied-tcp","SOURCE":"s_syslog","PROGRAM":"udptest3","MSGFORMAT":"rfc3164","MESSAGE":"","LEGACY_MSGHDR":"udptest3","HOST_FROM":"127.0.0.1","HOST":"127.0.0.1"}
{"TRANSPORT":"rfc3164+proxied-tcp","SOURCE":"s_syslog","PROGRAM":"tcptest","MSGFORMAT":"rfc3164","MESSAGE":"","LEGACY_MSGHDR":"tcptest","HOST_FROM":"127.0.0.1","HOST":"127.0.0.1"}
Config option 2 results in
Result
{"TRANSPORT":"rfc6587+proxied-tcp","SOURCE":"s_syslog","MSGFORMAT":"raw","MESSAGE":"<13>1 2025-05-07T15:30:42.821903+00:00 myhost root - - [timeQuality tzKnown=\"1\" isSynced=\"1\" syncAccuracy=\"332000\"] udptest3","HOST_FROM":"127.0.0.1","HOST":"127.0.0.1"}
Using send-proxy-v2 in config v3 for haproxy I can see the headers added, but no IP info added
{"TRANSPORT":"rfc3164+proxied-tcp","SOURCE":"s_syslog","PROXIED_SRCPORT":"0","PROXIED_SRCIP":"","PROXIED_IP_VERSION":"0","PROXIED_DSTPORT":"0","PROXIED_DSTIP":"","PROGRAM":"udptest3","MSGFORMAT":"rfc3164","MESSAGE":"","LEGACY_MSGHDR":"udptest3","HOST_FROM":"127.0.0.1","HOST":"127.0.0.1"}
{"TRANSPORT":"rfc3164+proxied-tcp","SOURCE":"s_syslog","PROXIED_SRCPORT":"0","PROXIED_SRCIP":"","PROXIED_IP_VERSION":"0","PROXIED_DSTPORT":"0","PROXIED_DSTIP":"","PROGRAM":"tcptest","MSGFORMAT":"rfc3164","MESSAGE":"","LEGACY_MSGHDR":"tcptest","HOST_FROM":"127.0.0.1","HOST":"127.0.0.1"}
For testing I’ve been using commands:
  • logger --tcp --port 514 -n 10.0.0.1 tcptest
  • logger --port 514 -n 10.0.0.1 udptest3
Am I doing something wrong here?
EDIT:
If I use this Haproxy config below, everything works fine, but then UDP input for syslog is not supported!
listen sng
  bind 10.0.0.1:514
  server server1 127.0.0.1:514 maxconn 32 send-proxy-v2
Config Option 1
haproxy
   log stderr format iso local7
ring myring
    description "My local buffer"
    #format rfc5424
    maxlen 2400
    size 32764
    timeout server 10s
    # syslog tcp server
    server mysyslogsrv 127.0.0.1:514 send-proxy
log-forward sylog-loadb
    dgram-bind 10.0.0.1:514
    bind 10.0.0.1:514
    # all messages on local tcp syslog server
    log ring@myring format rfc5424 local0
syslog-ng
source s_syslog {
    network(
        port(514)
        ip(127.0.0.1)
        transport(proxied-tcp)
        flags(syslog-protocol)
destination d_logs {
    file("/var/log/$YEAR-$MONTH-$DAY.log" template("$(format-json --scope nv-pairs)\n"));
    #file("/var/log/$YEAR-$MONTH-$DAY.log");
log {
    source(s_syslog);
    destination(d_logs);
Config Option 2
haproxy
ring myring
    #format rfc5424
    maxlen 2400
    size 32764
    timeout server 10s
    # syslog tcp server
    bind 10.0.0.1:514
syslog-ng
# transport support for proxied-tcp is new with 4.8
source s_syslog {
     syslog(
         port(514)
         ip(127.0.0.1)
         transport("proxied-tcp")
         flags(no-parse)
log {
    source(s_syslog);
Config Option 3
haproxy
ring myring
    #format rfc5424
    maxlen 2400
    size 32764
    timeout server 10s
    # syslog tcp server
    server mysyslogsrv 127.0.0.1:514 send-proxy-v2
    bind 10.0.0.1:514
syslog-ng
source s_syslog {
    network(
        port(514)
        ip(127.0.0.1)
log {
    source(s_syslog);
Because this was the first Google result for me:
send-proxy/send-proxy-v2 is only supported for tcp + http contexts, not for log-forward.
Considering proxy protocol was made by haproxy, and other software does support this… it’s at least interesting.
Was researching this when trying to decide for a logging loadbalancer too, and I’m back to considering nginx now, although I’d prefer to use haproxy…
This was discussed on github, you can find the conversation here:
In short: send-proxy requires the connection to be used for just a single source-IP, because it can only communicate the client IP once (at the very beginning of the TCP session). However log-forward aggregates log messages from multiple sources, as such it cannot use send-proxy.
Your only choice is the move the information in the application layer, for example with option host
