Running HA-Proxy version 2.0.25-1ppa1~xenial on Ubuntu 16.04.7 LTS
We are seeing a large amount of “Connection closed during SSL handshake” messages logged - 25% of messages logged.
I ran tshark to capture traffic. From investigating 1 affected IP my findings were:
- The log message “Connection closed during SSL handshake” occurs when there is no handshake in progress.
- There are no handshake attempts prior to the error (at least in my capture window).
- Later HTTPS connections/handshakes from the affected IP to the server are successful.
- The message in the log seems to coincide with a TCP-KEEPALIVE message from the client. The tcp-keepalive is sent to port 443.
I have a basic theory that the TCP-KEEPALIVE messages are being logged as Connection closed during SSL handshake
I’ve had a look at the haproxy source code specifically file ssl_sock.c. Please let me know if I’m barking up the wrong tree.
- A query to openssl
SSL_Get_statereturns a state of TLS_ST_BEFORE (Means no handshake messages have yet been been sent or received.). - empty_handshake is set
empty_handshake = state == TLS_ST_BEFORE; - There is an if statement:
if (!errno) { if (ctx->xprt_st & SSL_SOCK_RECV_HEARTBEAT) conn->err_code = CO_ER_SSL_HANDSHAKE_HB; else conn->err_code = CO_ER_SSL_EMPTY; } -
CO_ER_SSL_EMPTYis used in acasestatement to set the error:
case CO_ER_SSL_EMPTY: return "Connection closed during SSL handshake";
Any help on the issue and my “off on a tangent” theory would be gratefully received!
JD
