We want to achieve several 1000 concurrent connections to a webservice, running on Apache Tomcat.
The requests are very short, but there are really many of them.
We are still failing, because connections to backend are always (at least very often) closed and must be reopened.
Therefor connections on the backend servers are opened and closed too often and they run out of ports and cannot handle the amount of requests.
We hoped, the haproxy option “http-reuse always” would solve the problem. But it does not, because a connection to a backend server will be closed,
when the client disconnects, who initially opened the connection.
We already tuned the OS according to https://medium.com/@pawilon/tuning-your-linux-kernel-and-haproxy-instance-for-high-loads-1a2105ea553e
we run haproxy 1.8.13 and apache tomcat 7.0.90, both on linux (ubuntu 16.04)
What else can we do?
here is our (simpilifed) haproxy.cfg:
log /dev/log local0 notice
tune.ssl.cachesize 1000000
ssl-default-bind-options no-sslv3 no-tls-tickets # force-tlsv12
maxconn 1000000
# Enable the statistics page
listen haproxy-stats-process-1
bind *:9001
stats uri /
timeout client 60m
timeout connect 60m
timeout server 60m
option logasap
option log-separate-errors
option log-health-checks
option dontlog-normal
option prefer-last-server
timeout http-keep-alive 120000
no option httpclose
no option http-server-close
no option forceclose
http-reuse always
timeout check 15000
default-server inter 1s fall 2 rise 2
frontend default_http
bind ipv4@*:80
default_backend pool_default_http
maxconn 500000 # per process!!
timeout client 30m
timeout connect 60m
timeout server 60m
balance static-rr
hash-type consistent
option httpchk GET / HTTP/1.1\r\nHost:\ www
http-check expect status 200
http-reuse always
timeout check 15000
server test_1 10.205.1.161:8080 maxconn 20 weight 1 check
server test_2 10.205.1.162:8080 maxconn 20 weight 1 check
server test_3 10.205.1.163:8080 maxconn 20 weight 1 check
server test_4 10.205.1.164:8080 maxconn 20 weight 1 check
timeout client 30m
timeout connect 1m
timeout server 60m
