Sometime we have quite alot of the msg below in the log files.
The data transfer time td = ta-tr and in this case it is 20038-38 = 20000 (20s). It is wait too long for just 919 bytes.
The statsus code is 200 so I guess server transfered data to HA. However the data is not transfered to client and the client already close the connection. I’m not sure if there is a network issue between our backend and HA or HA and the client
I checked the configuration and see that we have “timeout client 20s”. I guess that client doesn’t ack get response and that is the reason for cL termination code and HA has no idea if client get the response. Is it right?
c : the client-side timeout expired while waiting for the client to
send or receive data.
L : the proxy was still transmitting LAST data to the client while the
server had already finished. This one is very rare as it can only
happen when the client dies while receiving the last packets.
If this is true - the termination code is correct and there is no bug you are hitting in haproxy, then the client closed at a very specific moment (when the response from the server was fully received but the client didn’t).
It is not completely impossible that you are hitting a bug though. You will have to correlate if there are real issues with those requests, or get a complete network capture of a request like this.
thanks for the clarification. I found out that there was a problem with our server and it affect the data transfer time between HA and backend and HA and clients
@Tim, could explain your problem with your server please? I’m working on a possible bug with the exact same behavior. So I’m interested to have as much info as possible.
Our backend sudden response so slowly due to a problem with our caching System. I observed during that time the tr is much higher than tr (tr also high though)
