VServer with HAProxy
i rent 3 VServers each Server has his own Network.
is it possible to konfigure HAProxy with that?
If i Try my config in VMWorkstation in the Same network it works.
But not in the VServers.
its Look like this
frontend http_front
stats uri /haproxy?stats
default_backend http_back
backend http_back
server server1 x.x.x.x:80 check
server server2 x.x.x.x:80 check
Thank You
Rob
