I’m hosting a WebDAV server on my Synology NAS that is reachable from outside my LAN using my own domain.
HAproxy (v: 2.2.4-de45672) is running on my firewall (IPFire) with the configuration below (shortend).
Question: when accessing or better writing a file to my Synology, using URI https://webdav.mydomain.de/pw.kdbx I get an error 405 when the program (Keepass) that tries to write this files, is firing a MOVE command.
Mar 30 14:28:59 localhost.localdomain haproxy[1960]: 212.77.111.222:57100 [30/Mar/2021:14:28:59.877] http_https~ webdav_serv
er/webdav01 0/0/0/21/21 405 405 - - --NI 2/2/0/0/0 0/0 {webdav.mydomain.de||} "MOVE /pw.kdbx.tmp HTTP/1.1"
OTH, all runs well when the program uses the path https://webdav.mydomain.de/webdav/pw.kdbx instead.
So, question is: where is the error in my config? Can you please give my any hint to correct this?
Thanks,
Michael
log 127.0.0.1 local1
stats socket /var/run/haproxy.sock mode 600 level admin
stats timeout 2m
pidfile /var/run/haproxy.pid
maxconn 4000
user nobody
group nobody
tune.maxrewrite 4096
option redispatch except 172.0.0.0/8
timeout http-request 30s
timeout queue 1m
timeout connect 30s
timeout client 1m
timeout server 1m
timeout http-keep-alive 30s
timeout check 30s
maxconn 3000
# Frontend Configuration
frontend http_https
bind 172.17.0.2:80
http-request replace-header destination ^https(.+) http\1
http-response set-header Strict-Transport-Security max-age=31536000
http-response set-header X-Xss-Protection 1;\ mode=block
http-response set-header X-Robots-Tag none
http-response del-header Server
http-response set-header X-Content-Type-Options: nosniff
http-response set-header Referrer-Policy no-referrer-when-downgrade
#Backend Configuration
acl is_webdav_domain hdr_beg(host) -i webdav.mydomain.de
acl is_webdav_path path -i /webdav/
http-request replace-path /(.+) /webdav/\1 if is_webdav_domain !is_webdav_path
use_backend webdav_server if is_webdav_domain
acl is_webdav_path path_beg -i /webdav/
use_backend webdav_server if is_webdav_path
default_backend no_match
cookie WEBDAVSERVER insert indirect nocache
http-check disable-on-404
http-check expect status 401
option httpchk GET /webdav
server webdav01 192.168.1.11:5005 cookie webdav01 inter 60s
backend no_match
http-request deny deny_status 400
