Getting 405 method not allowed | using HAProxy on top of rest api
Hi, I am facing error after setting up HAProxy on top of two web servers which have a rest api each. I am getting 405 method not allowed error. Here is my configuration file below:
Could someone please look into this?
        log /dev/log    local0
        log /dev/log    local1 notice
        log     global
        mode    http
        option  httplog
        option  dontlognull
        timeout client  60000
        timeout server  70000
frontend localnodes
    bind *:8021
    acl valid_http_method method GET POST HEAD OPTIONS
    http-request deny if ! valid_http_method
    default_backend nodes
backend nodes
    #option httpchk POST /status
    #http-check expect status 200
    #option tcp-check
    option httpchk OPTIONS /
    #option httpchk HEAD /
    server web01 10.207.9.191:5005/webhooks/rest/webhook check
    server web02 10.206.247.45:5005/webhooks/rest/webhook check
        bind *:8082
        stats hide-version
        stats show-node
        stats uri /stats
        stats auth admin:mypassword
        stats refresh 5s
hello,
you may want to add PUT, DELETE, and any other rest verbs you may be using, in your acl
good luck
