Here’s the config /etc/haproxy/haproxy.cfg:
log /dev/log local1 debug
stats socket /var/run/haproxy/admin.sock level admin mode 660
setenv ACCOUNT_THUMBPRINT 'xxxxxxxxxxxxxxxxxxxxxx'
maxconn 4000
ca-base /etc/ssl/apache2/certs
crt-base /etc/ssl/apache2/private
ssl-dh-param-file /etc/haproxy/dhparams.pem
ssl-skip-self-issued-ca
# log-format "%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts %ac/%fc/%bc/%sc/%rc %sq/%bq"
compression algo gzip
compression type text/html text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy application/atom+xml application/javascript application/x-javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest
# option dontlog-normal
# option dontlognull
option httpclose
frontend http-in
# bind *:80
bind :::80 v4v6
# bind *:443 ssl crt /etc/haproxy/certs/www.myserver.org.pem
bind :::443 v4v6 ssl crt /etc/haproxy/certs/www.myserver.org.pem
bind quic4@0.0.0.0:443 name quic443 ssl crt /etc/haproxy/certs/www.myserver.org.pem proto quic alpn h3,h3-29,h3-28,h3-27 npn h3,h3-29,h3-28,h3-27 allow-0rtt curves secp521r1:secp384r1
http-response add-header alt-svc 'h3=":443"; ma=7200,h3-29=":443"; ma=7200,h3-Q050=":443"; ma=7200,h3-Q046=":443"; ma=7200,h3-Q043=":443"; ma=7200,quic=":443"; ma=7200'
http-request return status 200 content-type text/plain lf-string "%[path,field(-1,/)].${ACCOUNT_THUMBPRINT}\n" if { path_beg '/.well-known/acme-challenge/' }
# Redirect if HTTPS is *not* used
default_backend website
log /dev/log local2 debug
acl is_static path_beg /export/ /opencms/ /resources/ /javadoc/ /VAADIN/ /workplace /opencms-login/
# acl is_static path_beg /willi
acl is_website hdr_beg(host) -i www.myserver.org
acl is_cmssite hdr_beg(host) -i cms.myserver.org
use_backend website-static if is_website is_static
use_backend website if is_website
use_backend cmssite if is_cmssite
server www.myserver.org 127.0.0.1:8080
backend website
# http-request replace-header Destination ^([^\ :]*)\ /(.*) \1\ /opencms/\2
# http-request set-path /opencms%[path]
backend cmssite
server cms.myserver.org 127.0.0.1:8082
EDIT: Sorry, I goofed. Gave the wrong address in the openssl request. The TLS Handshake seems to work.
It starts like this:
$ openssl s_client -connect xx.xx.xx.xx:443
CONNECTED(00000003)
Can't use SSL_get_servername
depth=2 C = US, ST = New Jersey, L = Jersey City, O = The USERTRUST Network, CN = USERTrust RSA Certification Authority
verify return:1
depth=1 C = AT, O = ZeroSSL, CN = ZeroSSL RSA Domain Secure Site CA
verify return:1
depth=0 CN = www.myserver.org
verify return:1
Certificate chain
0 s:CN = www.myserver.org
i:C = AT, O = ZeroSSL, CN = ZeroSSL RSA Domain Secure Site CA
a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA384
v:NotBefore: Nov 14 00:00:00 2023 GMT; NotAfter: Feb 12 23:59:59 2024 GMT
1 s:C = AT, O = ZeroSSL, CN = ZeroSSL RSA Domain Secure Site CA
i:C = US, ST = New Jersey, L = Jersey City, O = The USERTRUST Network, CN = USERTrust RSA Certification Authority
a:PKEY: rsaEncryption, 4096 (bit); sigalg: RSA-SHA384
v:NotBefore: Jan 30 00:00:00 2020 GMT; NotAfter: Jan 29 23:59:59 2030 GMT
2 s:C = US, ST = New Jersey, L = Jersey City, O = The USERTRUST Network, CN = USERTrust RSA Certification Authority
i:C = GB, ST = Greater Manchester, L = Salford, O = Comodo CA Limited, CN = AAA Certificate Services
v:NotBefore: Mar 12 00:00:00 2019 GMT; NotAfter: Dec 31 23:59:59 2028 GMT
certificates follow…
And at the end:
read R BLOCK
HTTP/1.1 408 Request Time-out
Content-length: 110
Cache-Control: no-cache
Connection: close
Content-Type: text/html
<html><body><h1>408 Request Time-out</h1>
Your browser didn't send a complete request in time.
</body></html>
closed
