be_tnt
1
Hello!
In my haproxy log, I can see multiple entries like:
Sep 23 15:03:34 localhost haproxy[16197]: IP:XXX.XXX.XXX.XXX - 14258 - [23/Sep/2020:15:03:34.737] - http_front - http_front/<NOSRV> - {www.website.com} - 302 - "GET /suggestion-du-mois/ HTTP/1.1"
What does it mean exactly? Is this an issue indicator?
Thx!
jerome
2
As documented (look for server_name)
If the request was aborted before reaching a server, "<NOSRV>" is indicated instead of a server name.
It can happen if you redirect, deny, … on the request path, or if no server is available to handle your request.
be_tnt
3
Thx for the explanation. I checked further the log and indeed I can see that this is indeed redirection (302)
