Hi guys,
I’m running a rocket chat server on port 3000 which I secured with ha proxy. I thought I setup rocket chat with caddy to accept SSL connections on port 3000. So I configured haproxy backend to connect to port 3000 SSL:
backend RocketChat_ipvANY
id 102
timeout connect 30000
timeout server 30000
server RocketChat 192.168.10.215:3000 id 103 ssl verify none
It worked perfect, so I did not care further. Now, by instance, I checked caddy on the rocket chat, it was not working for some reason and I could not open the rocket chat server via the IP and HTTPS directly. It only works via IP and HTTP. But, if I connect through haproxy, everything works fine. In the haproxy logs I can see some SSL failures but it’s working. So does the haproxy use some kind of HTTP fallback here, if HTTPS is not working?
Thanks for a short answer…
Chris
