I use haproxy(1.8.4) to terminate ssl and then send clients to backend servers based on alpn negotiation. I’ve recently added solr to the mix, and would rather have it sit behind SSL, but pretty sure i can not use hdr_beg in https, b/c i’m effectively in tcp mode. I can easily configure it like lets-encrypt in http mode. Mostly i’m just curious if there is a way to make this work.
Thanks!
relevant portions of the config
frontend http
bind 0.0.0.0:80
#if this is a LE Request send it to a server on this host for renewals
acl letsencrypt-request path_beg -i /.well-known/acme-challenge/
redirect scheme https code 301 unless letsencrypt-request⋅
use_backend letsencrypt-backend if letsencrypt-request
frontend https
#mode tcp
bind 0.0.0.0:443 ssl crt /etc/haproxy/certs alpn h2,http/1.1 ecdhe secp384r1
timeout http-request 10s
log-format "%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts \ %ac/%fc/%bc/%sc/%rc %sq/%bq SSL_version:%sslv SSL_cypher:%sslc SNI:%[ssl_fc_has_sni]"
acl solr-request hdr_beg(host) -i solr.
use_backend solr-backend if solr-request
#send all HTTP/2 traffic to a specific backend
use_backend http2-nodes if { ssl_fc_alpn -i h2 } !solr-request
#send HTTP/1.1 and HTTP/1.0 to default, which don't speak HTTP/2
default_backend http1-nodes
server solr01 10.X.X.16:8983
acl network_allowed src NN.NN.NN.NN
http-request deny if !network_allowed
Ultimately this always gets sent to the H2 block
