I’m trying to loadbalance a few dovecot instances and the SSL cert being shown to the users is the dovecot server’s not the HAproxy version. The documentation for this is sparse and scattered, so I couldn’t make a perfect setup that gave valid ssl certs. Does each dovecot server need to have a cert with the haproxy domain for this to work?
Here’s my config:
listen webForward
bind :443 ssl crt /etc/ssl/private/certprivkey.pem no-sslv3
#mode tcp
default_backend www-backend
backend www-backend
#mode tcp
stick-table type ip size 200k expire 30m
stick on src
server s1 6x.xxx.xx.xxx:443
listen dovecot-imap
bind :993
#option ssl-hello-chk
balance first
tcp-check connect port 993
tcp-check expect string *\ OK
stick-table type ip size 200k expire 15m
stick on src
timeout server 1m
timeout connect 1m
timeout client 5m
server s1 10.0.0.1:10993 send-proxy-v2
server s2 10.0.0.2:10993 send-proxy-v2
