Trying to et HAProxy to work with Gitlab, I have it working with confluence just fine. I have the port open on all the remote server.
Here is my config so far:
option log-health-checks
option allbackups
#option forwardfor except 127.0.0.0/8
timeout check 10s
maxconn 20000
listen stats 10.150.1.61:1936
#option httpclose
stats show-legends
stats uri /
stats refresh 5s
stats show-node
frontend smtp_inbound
bind 0.0.0.0:25
default_backend smtp_outbound
log-format {"type":"haproxy","timestamp":%Ts,"http_status":%ST,"http_request":"%ci","bytes_read":%B,"upstream_addr":"%si","backend_name":"%b","retries":%rc,"bytes_uploaded":%U,"upstream_response_time":"%Tc","session_duration":"%Tt","termination_state":"%ts"}
frontend confluence_f
bind 10.150.1.61:80 name confluence.borg.local
default_backend confluence_b
frontend gitlab_in
default_backend gitlab_out
timeout client 6h
reqadd X-Forward-Proto:\ http
acl host_npm hdr(host) -i gitlab1.borg.local
acl host_gitlab_ci hdr(host) -i gitlab1.borg.local
acl host_gitlab hdr(host) -i gitlab1.borg.local
# static backend for serving up images, stylesheets and such
option smtpchk HELO mta1.borg.local
# timeout server 1m
# timeout connect 40s
server mta1.borg.local 10.150.1.75:10024 send-proxy
server wayne 10.20.30.69:10025 send-proxy
# round robin balancing between the various backends
#backend app
# balance roundrobin
# server app1 127.0.0.1:5001 check
# server app2 127.0.0.1:5002 check
# server app3 127.0.0.1:5003 check
# server app4 127.0.0.1:5004 check
backend confluence_b 10.150.1.61:80
option httpchk
option httpchk OPTIONS /
#option redispatch
cookie JESSIONID prefix
appsession JSESSIONID len 52 timeout 6h
cookie LB insert
server confluence1 10.150.1.65:8090 check inter 5000
backend gitlab_out
option httpclose
server gitlab1 10.150.1.65:8080
Not sure what I’m doing wrong.
