Hi, I am having troubles with this setup,
Traffic forwarded from haproxy01 is being sent to marathon-lb with the following configuration:
spread-checks 5
max-spread-checks 15000
maxconn 50000
ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:!aNULL:!MD5:!DSS
ssl-default-bind-options no-sslv3 no-tlsv10 no-tls-tickets
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:!aNULL:!MD5:!DSS
ssl-default-server-options no-sslv3 no-tlsv10 no-tls-tickets
stats socket /var/run/haproxy/socket
server-state-file global
server-state-base /var/state/haproxy/
lua-load /marathon-lb/getpids.lua
lua-load /marathon-lb/getconfig.lua
lua-load /marathon-lb/getmaps.lua
lua-load /marathon-lb/signalmlb.lua
backlog 10000
maxconn 10000
timeout connect 3s
timeout client 30s
timeout server 30s
timeout tunnel 3600s
timeout http-keep-alive 1s
timeout http-request 15s
timeout queue 30s
timeout tarpit 60s
bind 0.0.0.0:9090
balance
monitor-uri /_haproxy_health_check
acl getpid path /_haproxy_getpids
http-request use-service lua.getpids if getpid
acl getvhostmap path /_haproxy_getvhostmap
http-request use-service lua.getvhostmap if getvhostmap
acl getappmap path /_haproxy_getappmap
http-request use-service lua.getappmap if getappmap
acl getconfig path /_haproxy_getconfig
http-request use-service lua.getconfig if getconfig
acl signalmlbhup path /_mlb_signal/hup
http-request use-service lua.signalmlbhup if signalmlbhup
acl signalmlbusr1 path /_mlb_signal/usr1
http-request use-service lua.signalmlbusr1 if signalmlbusr1
frontend marathon_http_in
acl host_status_embl_de_itsops_status-page_cachet hdr(host) -i status.embl.de
redirect scheme https code 301 if !{ ssl_fc } host_status_embl_de_itsops_status-page_cachet
frontend marathon_http_appid_in
bind *:9091
use_backend %[req.hdr(x-marathon-app-id),lower,map(/marathon-lb/app2backend.map)]
frontend marathon_https_in
bind *:443 ssl crt /etc/ssl/cert.pem
use_backend %[ssl_fc_sni,lower,map(/marathon-lb/domain2backend.map)]
frontend itsops_status-page_cachet_8000
bind *:8000
use_backend itsops_status-page_cachet_8000
server 10_11_6_32_9_0_1_130_8000 9.0.1.130:8000
Traffic seems to be only getting to *443 frontend, bot not being passed to the app frontend.
