Hi
I was wondering if someone could shed some light on the issue im having,
Currently have 2 sites on my backend a wordpress and zimbra email server,
they both have the SSL on each server, the idea is to passthough to those servers
but on the log i keep seeing
SharedFrontend-merged Backend1_ipv4/ -1/-1/6 0 SC 1/1/0/0/0 0/0
Thank you
root@bunker:/var/log# cat /etc/haproxy/haproxy.cfg
# user haproxy
# group haproxy
#ca-base /etc/ssl/certs
#crt-base /etc/ssl/private
#ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
#ssl-default-bind-ciphersuites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256
#ssl-default-bind-options ssl-min-ver TLSv1.2 no-tls-tickets
frontend SharedFrontend-merged
bind *:443
timeout client 30000
acl wordpress req.ssl_sni -i wordpress.domain.co
acl zimbra req.ssl_sni -i mail.domain.co
tcp-request connection set-src str(192.168.7.123) if { src 192.168.7.0/24 }
use_backend Backend2_ipv4 if zimbra
use_backend Backend1_ipv4 if wordpress
frontend HTTPTOHTTPS
acl wordpress var(txn.txnhost) -m str -i wordpress.domain.co
acl zimbra var(txn.txnhost) -m str -i mail.domain.co
http-request redirect scheme https if wordpress
http-request redirect scheme https if zimbra
id 10103
timeout connect 30000
timeout server 30000
source ipv4@ usesrc clientip
server zimbra 192.168.7.245:443 id 10104 check inter 1000
id 10101
server wordpress 192.168.7.35:443 id 10102 check inter 1000
