i have a haproxy setup on a virtual machine using kvm with 8 cores and 4Gb of memory.
i,m using it as a load balancer with SSL offloading(with verify required).
the server has a load average of 1.7 and is using only about a gigabyte of memory.
the SSL offload takes about 450ms.
my question is why the server is not using the full resources to decrease response time.
what is causing the event loop to stall.
i have enabled multi process in my config
here is the configuraion:
nbproc 8
cpu-map 1 0
cpu-map 2 1
cpu-map 3 2
cpu-map 4 3
cpu-map 5 4
cpu-map 6 5
cpu-map 7 6
cpu-map 8 7
log 127.0.0.1 local0
maxconn 20000
uid 99
gid 99
tune.ssl.cachesize 1000000
tune.bufsize 32768
stats socket /var/run/haproxy1.sock mode 600 level admin process 1
stats socket /var/run/haproxy2.sock mode 600 level admin process 2
stats socket /var/run/haproxy3.sock mode 600 level admin process 3
stats socket /var/run/haproxy4.sock mode 600 level admin process 4
stats socket /var/run/haproxy5.sock mode 600 level admin process 5
stats socket /var/run/haproxy6.sock mode 600 level admin process 6
stats socket /var/run/haproxy7.sock mode 600 level admin process 7
stats socket /var/run/haproxy8.sock mode 600 level admin process 8
stats timeout 2m #Wait up to 2 minutes for input
#listen stats
# bind :9001
# mode http
# stats enable
# stats hide-version
# stats realm Haproxy\ Stats
# stats uri /haproxy_stats
# stats auth admin:sfPalang
# stats admin if TRUE
maxconn 10000
# option httplog
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
frontend https_frontend
bind 0.0.0.0:443 ssl crt PEM_FILE ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:!DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA ca-file /home/arsalan/rootCA.pem verify required process 1-8
option httpclose
SOME BACKEND CONFIGS (http backends with roundrobin config)
