Hi community! \o/
After upgrading from HAProxy 2.3.7 to 3.1.7, I’ve encountered an issue that did not occur with the previous version. Here’s our setup:
- A VPN client connects to an AWS NLB listening on port
10443. - The NLB forwards traffic to a HAProxy server (target group) on port
10443, using a specific IP 192.168.1.1 - HAProxy is configured as follows:
log 127.0.0.1:514 local0
pidfile /var/run/haproxy.pid
maxconn 10000
quiet
tune.lua.bool-sample-conversion normal
lua-load /etc/haproxy/mailers.lua
defaults main
option contstats
timeout http-request 10s
timeout queue 1m
timeout client 5m
timeout server 5m
timeout http-keep-alive 10s
timeout check 10s
maxconn 10000
frontend vpn
bind 192.168.1.1:10443
default_backend vpn_backend
backend vpn_backend
server vpnserver 192.168.1.10:443
The HAProxy server has two IP addresses:
192.168.1.1192.168.1.2(used for another frontend)
The issue:
After the upgrade, the VPN backend server started detecting a potential DoS attack. It logs messages like:
A DoS attack on the TCP Listener (port 443) has been detected. The connecting source IP address is 192.168.1.2, port number is 52442. This connection will be forcefully disconnected now.
This is likely because HAProxy was sending backend traffic using the 192.168.1.2 IP, which caused the VPN server to start blocking those connections.
Workaround so far:
I updated the backend line to explicitly set the source IP:
server vpnserver 192.168.1.10:443 source 192.168.1.1
That partially fixed the issue — after restarting HAProxy, VPN connections started working again. But eventually, I noticed that some health checks also started coming from 192.168.1.1, which the VPN server still interprets as a threat and closes the connection.
In the HAProxy statistics page, the backend for the VPN (vpn_backend) shows "no check" — so health checks are disabled.
I wouldn’t expect HAProxy to perform any checks, yet the VPN server continues receiving connections that look like health checks, coming from the NLB to HAProxy’s IP (192.168.1.1).
It feels as if something is bypassing HAProxy and hitting the VPN server directly, but using HAProxy’s IP.
Any idea how can I ensure that HAProxy uses only the correct source IP (192.168.1.1) for prevent these unwanted checks or connections from reaching the VPN server?
Any help or clarification would be greatly appreciated!
Thanks in advance,
