Hi there. I’ve been trying to configure HAProxy to balance sadly old IIS sites using CCS (Centralized Certificate Store) feature without success. I get an SSL handshake failure.
Disabling CCS on the same site binding and selecting the same certificate manually all works fine.
_version=2187
Dataplaneapi managed File
changing file directly can cause a conflict if dataplaneapi is running
master-worker
nbproc 1
nbthread 2
cpu-map auto:1/1-2 0-1
maxconn 100000
stats socket /run/haproxy/admin.sock user haproxy group haproxy mode 660 level admin
stats timeout 2m
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384
log 127.0.0.1:514 local0
description HAProxy Balancer
tune.ssl.cachesize 1000000
maxconn 100000
cookie serverid indirect nocache insert
no option http-use-htx
timeout client 50s
timeout server 50s
errorfile 502 /etc/haproxy/errors/502-custom.http
errorfile 503 /etc/haproxy/errors/503-custom.http
userlist controller
user user password ###
peers lb-peers
peer haproxy1 haproxy1:1024
peer haproxy2 haproxy2:1024
frontend admin-statistics-frontend
bind :9099
stats uri /
stats auth ##:##
stats show-node
stats show-legends
stats refresh 300s
stats admin if TRUE
stats show-desc
frontend f1
bind 192.168.20.101:80
frontend f2
bind 192.168.20.101:443 ssl crt /etc/ssl/certificates/pem alpn h2,http/1.1
acl site1-acl hdr(host) -i site1
acl site2-acl hdr(host) -i site2
acl site3-acl hdr(host) -i site3
http-request set-header x-forwarded-proto https
http-request set-header X-ARR-SSL greatscott
use_backend site1 if site1-acl
use_backend site2 if site2-acl
use_backend site3 if site3-acl
backend site1
option httpchk GET https://site1.domain.com
server server1 server1:443 enabled weight 1 cookie dQBhAHQAMQAtADcA check ssl verify required ca-file /etc/ssl/certs/ca-certificates.crt
backend site2
option httpchk GET https://site2.domain.com
server server2 server2:443 enabled weight 1 cookie dQBhAHQAMQAtADcA check ssl verify required ca-file /etc/ssl/certs/ca-certificates.crt
backend site3
option httpchk GET https://site3.domain.com
server server3 server3:443 enabled weight 1 cookie dQBhAHQAMQAtADcA check ssl sni req.hdr(host) verify required ca-file /etc/ssl/certs/ca-certificates.crt
The configuration of site3 is the one I’m trying with CCS.
Thanks in advance for any help you could give me.
