I’m using Dataplane API to update HAProxy configuration and everything works well except the new version of configuration has a different order of directives under backends and frontends. To give an example, let’s say I have this pseudo backend block;
backend be_static
http-request set-header Host example.net
http-response add-header Set-Cookie my_cookie=%[var(txn.my_cookie)]
server example example.net ssl verify none sni str(example.net)
After adding another backend with Dataplane API my be_static backend ends up in this order;
backend be_static
and it breaks the functionality. Not only backends but my frontend configurations suffer from this change of order too after an API commit. For example;
capture request header Referer len 200
capture request header User-Agent len 200
log-format %ci\ -\ %{+Q}r\ %ST\ %U\ %{+Q}[capture.req.hdr(0)]\ %{+Q}[capture.req.hdr(1)]\ %{+Q}b\ %{+Q}s
use_backend %[base,lower,map_beg(api.map)]-http if { path_beg /api }
use_backend %[base,lower,map_beg(http.map)]
becomes
Any idea why this happens or a workaround to prevent it happening?
Thanks in advance
# haproxy -vv
HA-Proxy version 2.0.14-1ppa1~bionic 2020/04/16 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-vOKb8p/haproxy-2.0.14=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Built with PCRE2 version : 10.31 2018-02-12
h2 : mode=HTTP side=FE mux=H2
<default> : mode=HTX side=FE|BE mux=H1
<default> : mode=TCP|HTTP side=FE|BE mux=PASS
Available services :
prometheus-exporter
