I believe I may have found a bug, and if so not sure where to report it. Your feedback is very much appreciated.
So, here it goes. This config will check every 5s interval.
backend www
default-server inter 5s fall 3 rise 2
server test 1.2.3.4:80 check
and this config will check every 2s interval.
backend www
why?
Shouldn’t it be 5s for both?
HAProxy version 1.6.3, released 2015/12/25
Thanks,
Sam
This is simply related to the way HAProxy parses a configuration file.
I think the documentation is not accurate enough and should report that default-server applies for the servers below it, (and mybe until the next default-server directive).
That is surprising.
The official Chef cookbook got it wrong GitHub - sous-chefs/haproxy: Development repository for the haproxy cookbook
configuration.txt is 15,000 lines long and so it will be a needle in a haystack. I wonder if a warning message at startup would make sense. Or, if the code should change, since this is a configuration file, and they are usually not dependent on ordering. … unless this is an intentional feature, which it may be.
No warning message, since this type of configuration may be valid in some cases.
