Please review below template and suggest any improvement that could be done in order to protect haproxy host and websites in the backend… Please if possible copy and paste the text as it should be included.
timeout connect 3s
timeout client 5s
timeout server 5s
timeout http-request 5s
timeout http-request 10s # Preventing Slowloris like attacks
option http-buffer-request
frontend haprx01
bind 192.168.1.6:80
bind 192.168.1.6:443
http-request deny if HTTP_1.0
http-request deny if { req.hdr(user-agent) -i -m sub curl phantomjs slimerjs }
http-request deny unless { req.hdr(user-agent) -m found }
http-request deny if { src -f /etc/haproxy/blacklist.acl }
default_backend websites
backend websites
stick-table type ip size 1m expire 10s store http_req_rate(10s)
tcp-request inspect-delay 10s
tcp-request content track-sc0 src
http-request deny if { sc_http_req_rate(0) gt 10 }
server web01_v2 192.168.1.4:443 check
server web02_v2 192.168.1.5:443 check
#the main goal of this ACL is to deny access to backend if the request is not from HAproxy 192.168.1.0/24
#ubuntu - HAProxy restrict single backend by ip range - Stack Overflow
acl white_list src 192.168.1.0/24
tcp-request content accept if white_list
tcp-request content reject
