I am using HAProxy (Community Edition) for a Redis Server access (High Availability for a master-slave Redis setup).
It runs on a Debian Stretch (9.9) LXC container installed from the apt repository haproxy.debian.net.
After upgrading from HAProxy 1.9.8-1~bpo9+1 to 2.0.1-1~bpo9+1, I noticed a server connection issue: Server connections on Redis grew up from about 50 connections to 4000, making Redis Server unavailable under peak periods.
After downgrading to 1.9.8-1~bpo9+1, everything was back to its original state (server connections came back to around 50).
Usually, the number of client connections is around 50, but can reach 500 under certain circumstances.
Is there a change between 1.9.x and 2.0.x that could explain this problem?
Here is my HAProxy configuration file (same conf used for v1.9.8 and 2.0.1):
maxconn 32000
option dontlog-normal
frontend redis_master
bind 10.2.1.100:6379,10.2.1.101:6379
timeout client 10s
default_backend redis_master
balance first
timeout connect 4s
timeout server 10s
option tcp-check
default-server rise 1 on-marked-down shutdown-sessions
server 10.2.1.3 10.2.1.3:6379 check #disabled
server 10.2.1.4 10.2.1.4:6379 check disabled
