I am having trouble getting Microsoft Remote Desktop Services to redirection remotefx devices. Specifically scanners when connecting through HAProxy. It does work, but the speed is incredibly slow. 5min per page to scan!
It works perfectly fine if I bypass HAProxy when connecting. I am using HAProxy to balance the RDS rdweb servers.
Here is my config
#log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
#turn on stats unix socket
#utilize system-wide crypto-policies
ssl-default-server-ciphers PROFILE=SYSTEM
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
frontend rds_frontend
bind frontend:443
default_backend rds_gateway
backend rds_gateway
balance source
server server1 server1:443 maxconn 1000 weight 10 check
server server2 server2:443 maxconn 1000 weight 10 check
bind backend:8080
stats uri /stats
stats refresh 10s
stats admin if LOCALHOST
I am completely at a lose. Any help would be appreciated!
