I am new to HaProxy, i confirm the base base url in firsttime, i having 3 api’s in that 2 api’s working fine only one api’s getting 404 not found error.
I check that api is working fine and i use telnet command to check any blocking of network. it also look good. i am using haproxy:2.4v
you can find my haproxy.cfg file here.
log /var/log/haproxy/haproxy.log local2
# chroot /var/lib/haproxy/
ssl-default-bind-options ssl-min-ver TLSv1.2
frontend http
bind *:443 ssl crt /etc/haproxy/certs/collector.xxxx.xxx.com.pem ssl-min-ver TLSv1.2
http-request set-header X-Forwarded-Proto http if !{ ssl_fc }
acl PATH_collector path_beg -i /collector
acl PATH_taskmetric path_beg -i /taskmetric
acl PATH_nats path_beg -i /
use_backend collector if PATH_collector
use_backend nats if PATH_nats
use_backend taskmetric if PATH_taskmetric
backend collector
server collector 10.x.x.x:8081
backend nats
server nats 10.x.x.x:8222
#backend taskmetric
# mode http
# server taskmetric 10.x.x.x:8082
# http-request replace-path /taskmetric(/)?(.*) /\2
# option http-server-close
# option forwardfor
# http-request add-header X-Forwarded-Proto https if { ssl_fc }
# http-request set-header X-Forwarded-Port %[dst_port]
# http-request set-header X-Debug-Path %[path]
backend taskmetric
http-check send meth GET uri /
All my api’s running as docker swarm.
thanks in advance
