Hello
I have this setup
- HAProxy Server
- Two Nginx web servers
I need to redirect user according to the URLs
But the URLs is variable not static URLs (domainname/variablename)
I used (balance url_param id) but it isn’t work
This is my haproxy configuration
frontend haproxynode
bind *:443 ssl crt /etc/haproxy/certs/domainname.pem
default_backend backendnodesbackend backendnodes
option httpchk
hash-type consistent
option httpchk HEAD / HTTP/1.1\r\nHost:localhost
server node1 x.x.x.x:4444 check ssl verify none
server node2 x.x.x.x:4444 check ssl verify none
Kindly i need your support
