I am trying to use haproxy (on front machine) with shiny server (on backend machine). I have apache and wordpress on the backend machine too.
The proxy code examples for shiny server on the web are primarily for NginX and Apache. Shiny server uses websockets, I have been successful in using haproxy to connect to wordpress site through apache. However, I cannot get haproxy to work with shiny server where the client can either go to the wordpress site or to the shiny port.
I know that the shiny server works, since a). I can observe the demo code when I open the browser on the backend machine directly, and b). when I put in a proxy (following the link shown above) code in 000-default.conf for shiny, the website shows the shiny interface (instead of the wordpress interface). I am not sure how I can tell haproxy to switch between the two ports (80 for wordpress site, and 3838 for http of shiny site). Been banging my head against this problem for the last two days; any help would be really appreciated.
System config is: ubuntu 18.04 LTS, haproxy1.8.9-1ppa1~bionic, apache2.4.29, shiny-server
My current haproxy config file code is:
maxconn 2048
ssl-default-bind-ciphers
stats uri /stats
stats auth username:password
frontend www-http
bind FrontserverIPaddress:80
default_backend www-backend
frontend www-https
bind frontendserverIPaddress:443 ssl crt /etc/ssl/private/datacolaboratory.com.pem
timeout client 120s
option http-pretend-keepalive
acl is_websocket hdr(Upgrade) -i WebSocket
acl is_websocket hdr_beg(Host) -i ws
acl host_daco hdr_sub(Host) -i datacolaboratory.com
use_backend bk_rshinyproxy if is_websocket host_daco
backend www-backend
server www-1 backendserverIPaddress:80 check
option forceclose
balance source
timeout tunnel 1200s
server shiny backendserverIPaddress:3838 weight 1 maxconn 1024 check
