Hi ,
I am new to haproxy i installed it and configure to run it in port 2222 .
after that security scan was done by the org and i got port 2222 is using weak algorithms like below . The scan report is these type weak algorithm are supported or enable in port 2222.
can any one help me to resolve these issue .
The following weak key exchange algorithms are enabled :
diffie-hellman-group-exchange-sha1
diffie-hellman-group1-sha1
The following client-to-server SHA-1 Hash-based Message Authentication Code (HMAC) algorithms are supported :
hmac-sha1
hmac-sha1-etm@openssh.com
OS using ubuntu 18.04
haproxy version 1.8.8
my configuration is like bellow :-
#ECDH+AES256:DH+AES256:ECDH+AES128
backend haproxy_scp
balance first
server fs1 someip:22 check
server fs2 anotherip:22 check
frontend haproxy_in
bind *:2222
log-format "%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts %ac/%fc/%bc/%sc/%rc %sq/%bq dst:%[var(sess.dst)] "
tcp-request content set-var(sess.dst) ssl_fc_sni
default_backend haproxy_scp
frontend stats
stats hide-version
stats refresh 30s
stats show-node
stats auth admin:password
stats uri /haproxy?stats
